have you thought about using a 2.5" to 3.5" IDE Cable instead of the adapter you have on that hard drive. Take a look at this LINK Would save...
i dont spose you no if he has performed any security updates laterly, namely the MS06-015. I had a problem recently where this update stopped...
I can believe that he did that at 40, my girlfriends mom had someone in a saxo drive into the side of her corsa and the wheels fell off the saxo...
A friend of mine has bought a new wireless router from a local pc shop and it seems to have a flacky wireless network (like most), so i was going...
actually i think you will find it is against there ToC, if you care to read the blue responce at the end of this forum post WoW Forum :read:...
Think youself lucky, i had to build a second computer and buy 2 accounts so that me and my girlfriend could play at the same time.
You are not alloud to do that and if you are found out you will get you account banned. THe only option is to buy two seperate accounts which is...
almost 99.9% it said the file was c:\windows\system32\defrag.exe which is the windows dos based defrag utility as you can run it from a comand...
I've been having a problem with my pc opening up a program that closes straight away and i think ive found out what it is. When im playing games...
You could always go down to a golf driving range and smack a few balls down. Not into golf myself but it could help release stress and any...
Wanted something a little better than that. doesnt log that much info. Ive used currports which is ok, but i need something that updates more and...
ill give it a go this weekend then guys, ill try adjusting the FSB but some people have had problems with the V3 boards running above 166 when...
Does anyone know of any programs that keep a log off all the processes and programs that run on your pc. Ive got a suspect program that keeps...
cant you get new 9800 pros for about £100 these days.
Have you done anything to aid cooling in yours?
I recently got a SN45gv3 shuttle and am now thinking about OC'in it a little. My processor is a xp-m 2500 currently running at stock (133x14 =...
they dont do it because it uses up too much bandwidth and people on dial have to wait ages for pages to load
please do, either that or take a dremel to his face :dremel: :naughty:
i cant stand him. what makes it even worse is that my neighbours son seems to love him and many other cRAP artisits (like 50cent to name another)...
i like both, but im trying to cut down. tend to only drink it at work or at other peoples houses as i cant be bothered to boil the kettle at home....
