I'm curious how this 40mm rad turns out. I contemplated even using those rads in my build, but TDP of parts I have is way higher than yours. I...
I find it weird that Noita is there on list and Hades is missing. This new title from Supergiant is one of the best indie games in recent times....
New CPU is in the box. [IMG] Using this occasion I can give fulls specs (another M2 drive could be installed, but SSD is boring part anyway)....
I don't think so, since on receipt only CPU is listed. For legal reasons some shops bundle Ryzen 4000 series with motherboards. Other shops...
For some reason I didn't take photo with the bag that they send me also, otherwise question wouldn't be necessary. It wasn't cheap for sure (same...
Decided to pull the trigger on Ryzen 4750g. I was surprised by package size and its content - I ordered just CPU. [IMG] The box on the left is...
I screwed big time when it comes to holes for top fans. I borrowed used angle drill, because there was too little space for anything else. It...
EPS cable in non-issue as you mentioned, especially since I have extender, so PSU will stay original. You can spot few more cables and some fans...
Almost too perfect, hence I got rid off IO shield, because I'm missing few millimeters. On the bright side access to IO is way better than I...
I got cooler and NVMe this weekend. I picked ID-Cooling IS-60 EVO: removed original fans and put only one Arctic P12 in pull mode, replaced...
First small change, but huge improvement. [img] I flipped hinges, so now doors open to the other side - no drilling, just removing some screws....
Sorry for delay, but I prefer to show things than talk about them if possible. Digital router cutter was used. Polycarbonate is probably last...
Modding begins [img] Original glass on the left and mount for fans made out of polycarbonate on the right. I decided not to go for grill-like...
I'm not surprised by price increase - that was to be expected if 5000 series can match or outperform solutions from Intel. I'll be getting new CPU...
X570 provides additional 16 lanes via chipset - this goes on top of what CPU provides. Huge number of PCIE lines is what X570 was made for. This...
I'm pretty sure it won't be live, since this is pre-recorded event.
Thanks for thinking so, I will try not to ruin original case. I printed motherboard on cardboard-like material in 1:1 scale for this reason. I...
As with almost every modern GPU, average power draw isn't good indicator for getting PSU. Today GPU's are highly transient (they are way better at...
Rumors about huge cache in Big Navi circled around for some time. On itself it isn't that interesting, but it could possibly mean that AMD is...
Very small update. I was going back and forth with different ideas. I pretty much abandoned idea of water cooling, since that would require...
