For a project of mine, I salvaged some standoffs from the connectors of some scrapped graphics cards. However the screw that goes into them...
I'd take a look at Dolphin Browser, Advanced Task Killer, and MoboPlayer.
Ah, I think you're right. Upon searching more I came upon this image [IMG] Looks extremely familiar, but I bought the card almost 4 years ago so...
Hi all, I've built a fairly plain media pc for the living room, but unfortunately the TV is a little dated. The best connection is through...
Hey, thanks for the responses guys. Very good info. However, I just remembered I have a spare HD 4350. Now this card has an s-video out. So I did...
Perhaps I was wrong in my post. My television set only has composite inputs, I'm assuming I was wrong in thinking the signal is related to VGA....
Hey guys. I currently have an Asus hd5850. I want to be able to play some games on my bedroom television, but unfortunately it's a CRT set. The...
Most retailers reserve the right to cancel orders if a price has been incorrectly posted and they have not charged you. It all depends on their...
does vinyl dye work on sata cables? Not sure if you can go from such a dark color to white, but vinyl dye generally colors the plastic material...
yea, that is probably a limitation of the wall style adapter itself. There are a few laptop style adapters that are around 6amps, but they...
You would need a power adapter that is 12v with enough amperage for the fans. It should say on the fans how many amps they draw, but most are...
good god.
This one is a sure purchase for me. Glad I didn't get a DSi yet. Also, pretty much certain an OoT remake has been confirmed by ninty themselves.
Unfortunately, Flash is a proprietary platform. Viewing and developing for Flash is more or less an Adobe ordeal. There are groups like Smoke...
Is the case open on both sides? If it is, you could position the mobo PCB in the center and place the SSDs on the other side to give it symmetry...
CPU: 6.7 Memory: 7.5 Graphics: 7.7/7.7 HDD: 5.9 DAMN YOU 5.9!!! Oh yeah, my old card was a 4850 512MB and it got a 7.3/7.3. Just saw someone...
That's actually a pretty well suited motherboard you've chosen. As DFI tends to be one of the few manufacturers that makes smaller sized form...
That is interesting. Dremel seems to make pretty decent products, so it all comes down to the price I guess.
jeez, finally. Haha, jk, can't wait!
I've probably only needed guides for a few sentences worth of information to help me past something I've gotten stuck on. IMO, any guide on...
