Thanks! I'll try it just to see what happens.
I just took it up to the point of the install seeing my hard drives.
I haven't thought about updating the firmware. I'll give that a try. I'm beginning to think that it is the opti drive. I don't have another to...
I was wondering the same thing. Take a look at this picture. Notice that the compatibility on the opti drive is none. But it's a SATA drive!...
Guys, you're missing the point. I want to reinstall... I'm not interested in saving/hacking my current OS install to change it from IDE to AHCI....
Motherboard: Gigabyte GA-MA785GPMT-UD2H CPU: AMD Phenom II X2 555 RAM: Corsair DDR3 4GB @ 669MHz Video: ATI Radeon HD 5750 PSU: OZC Mod...
Thanks Fishlock, and besides, I can't afford one of those monster PSU's anyway after looking at the price. I removed the 8600 and will stick with...
Sounds like it's a go then! :rock::thumb::clap:
The PSU in that case is a Antec Earthwatts 500W, by the way.
OK, so if the consensus is that I get another PSU, then what do you suggest? In the past I've always gone with what was cheaper, and realize that...
Oh, and the sound card I already have as well.
Power supply is 500w and comes with the case. The mobo is DDR2 and DDR3 capable, so that leaves room for upgrading the mem. Honestly, I only need...
First off, it's been a loooooooooooong time since I've built a PC. I'm talking AMD 2000+ with an ATI 64mg video card. Add to that I've been...
According to Slickdeals.net, ZipZoomFly has this case for $40. It comes with a $30 MIR making it $10. Pretty good deal, I think.
That's what I was thinking. I was going to ask about $8-10 for 9.2.1 and $12-15 for so for the 10.2. Quite a few of the other Mac OS sellers are...
First off, I've never installed any Mac OS before, so I know nothing about it. Second, I'm not sure if this is going in the right section. On to...
I say merge all threads. Even if the modder didn't want it merged, someone else could still post in the thread, couldn't they? Besides, this...
Update 17th April Another update, baby! [IMG]
Case re-assemble It's been a little while since I last posted. I've had a time trying to get started after taking a little vacation two weeks...
Sorry, I've been out on a small vacation so I wasn't able to reply. Looks good! Only problem is that I forgot that streaming is blocked at work,...
