Good! It's long overdue for PC games to require a 64 bit OS and more than 4 Gb of RAM. That 4 Gb limit has been holding things back for years -...
What's in a name? that which we call a rose By any other name would smell as sweet I've got the Enthoo Primo and it's a fantastic case. Who...
Looks good, my only concern is what monitors will integrate it. I can forsee it only being put into "gamer" branded monitors, with crappy TN...
Another vote for reasonably priced no-name ones here. I got one of these:...
If you aren't going to be overclocking it you could ditch that aftermarket CPU cooler and go with the bundled one - you went for a Retail rather...
You mean like this? http://www.scan.co.uk/products/arctic-accelero-hybrid-graphics-card-cooler-for-enthusiasts Got two, love them.
There is always some variation of course. I found I can take mine to 4.4 Ghz with no additional voltage, but it becomes unstable at 4.5, so I run...
It's called a "dear god no don't do it monitor speakers are horrible" cable
I can't say I had heard of that particular software, but assuming you were running it to attempt data recovery, I've had other tools take longer...
Just a little bit of advice on 6 pin to 8 pin PCI-E power cables adapters (may be a moot point now since you are getting a different PSU). I...
If they are available to you, check out PlusNet - they do manage traffic during peak times, but they are very clear about what, when, and how...
The only difference between buying an actual tri-channel kit as opposed to some other is that it comes with a guarantee from the manufacturer that...
Here's my experience with them - I had been hoping to fit the radiators in the roof of my case but sadly the need to use some adapter brackets...
I've got two cooling my 570's, and their performance is superb. The fitting is a bit of a pain but probably still much easier than full water cooling.
That would depend on the inputs on the screens and what resolution you want to drive them at. Is it going to be HDMI and 720p? Or 1080p? Without...
Personally I'd go for quad core anyway, just for the sake of future proofing, assuming you will play other games too. Multi-core support is...
If temps are your only concern, then stick with the standard cooler. As GoodBytes points out, you don't really need it to run at lower...
If spending £103 on a cooler is an option for you, I can heartily recommend this:...
Looking at reviews for that case it seems it comes with just a single 120 mm exhaust fan as standard, and space for another 120 mm intake. So, I...
:jawdrop: The card just below the fastest (single GPU model) from just one generation ago is "low end"? Do you upgrade to every new generation and...
