Whoever was let loose on the design needs to be fired, it's beyond words of how crap it is! The ad's ain't a problem. FireFox is your friend with...
I would, but I don't think you can have 40 odd pictures in one post?
Ok, so first serious mod. Wanting to lay on the heavy with UV green/green acrylic. Same goes for the lighting which will be green. Here's a...
Bah! While your buying some I'm trying to get rid of one! :( I'd go with the suggestion above. If you do get a few max out one with parts from...
Or paragraphs?
Pictures don't work for me.
I've taken it along with my MCSE, and most small firms will insist on this bloody annoying qualification. It's annoying to learn about old...
Cheers Springs. Might just be me, but I'm stubborn and like to learn how they are created rather than "borrowing" someone elses creation. :)
That link doesn't help at all? :confused: I asked for a site that has pictorials of how to make things like's shown on that page. Also, I in...
I'm wanting to make some sketchup designs of a PC I've got in the process of being modded. I've got the basics on how to use the draw feature....
Hardcore as in gabba? Or hardcore as in that grebo shite? If gabba, then check out Rotterdam Terror Corps. :D If that grebo shite, get a...
Sc4mpi, it's not nice to pimp your own rig in someone elses's thread. But otherwise, looks good. :)
Dirt cheap prices, $7 for what I want, shame the shipping is $69.14 though! :( :duh: But $31.25 with the slowest shipping (which would take...
Try www.acryan.com I'm also looking for some acrylic, pref 5mm thickness.
This is the UK, sign writers only exist in the very big cities! I've only had one reply back from a possible source, the rest haven't. Some...
I'm trying to find some 5 or 6mm thick UV Green acrylic. And having found a few suppliers, I've asked them for a quote for an up-coming mod, ;)....
404
Do you have your monitor cable near anything like a TV or a speaker? That can cause ghosting like you describe. If you do, try moving said...
How can they test if you've modded it or not?
[IMG]
