Final shots. Need to make a bracket for the GPU tubes because they are sagging. But for now it's a wrap! There are some things that I would like...
Thank you
Time to polish this plastic [ATTACH] [ATTACH] Crystal clear [ATTACH] Added these support brackets to help hold up magnetic sides [ATTACH]...
Here we go, final assembly! [ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH] Leak testing passed [ATTACH] Major air pocket. Always had this problem...
Here is the top panel of the case. Added the Rayfield logo (altered it a little), added the front I/O symbols and buttons and the mesh. [ATTACH]...
Painted the washers gold and the silver screws black. [ATTACH] Painted the case. This was difficult due to the weather being cold and had to wait...
Since I wanted to make this case as easy to maintenance as I can, I decided to add screws, with washers, to the side panel where the mesh will go...
Test fitting the PSU (this will be held up with supports) [ATTACH] Made a middle back piece to hide all the cable mess. This piece will only show...
Thank you. yea, I never really liked any of the sff cases. E-atx or super cases have been my personal choice.
Decided to add some washers (these will be painted gold, just to add a lil' splash of gold in here for the neokitsch type of look I'm going for)....
Been very busy, but here is what I have been working on so far: The front panel IO. Got this from a be quiet case (with the wireless charging)....
yea, that was a (duh!) moment lol
So, I had to do some modding to the hard drive tray so that I could mount the HDD from the bottom instead of the sides. I just used an exiting...
Quick lil' update: I worked on the HDD/SSD drive bay. I used a BeQuiet tray I had laying around (2 of these will be used to hold a HDD and 2...
Loving it!!!!
[MEDIA]
Slick! I've always liked the look of carbon fiber.
Yea, tedious and time consuming but loved the outcome.
Thank you. Yea that front and top panel took some time but I am happy with the progress so far.
Ok, ran into a slight issue with the monitor. The HDMI cord is blocking a USB port and some of the ethernet port and wifi. So decided to have it...
