Surely BT can get their hands on this board for a full review, even if its just 10 pages of phwoar. Its great to see EFI/BIOS screenshots with...
After reading the announcement about PCIe 6.0 spec I noted some funny numbers. The currently silly amounts of bandwidth available in newer PCIe...
That should be very interesting then. If BT has the budget for an IR camera (back of motherboard temperature measurement) or the Zen 2 parts...
With Zen 2 specifically I'd like to see "multi-tasking" benchmarks to see how memory bandwidth limits or does not limit the Zen 2 cores. By...
After your suggestion here I tried "splitting the difference". One kit is rated for DDR3-1600 VDRAM = 1.5V and the other is rated for DDR3-2133...
The testing was done at stock speed and still getting the problem. The 1600 16GB kit belongs to my work PC so I cannot match to that kit for this...
The work I do has forced me to mix and match RAM in my PC to temporarily increase capacity. The following is what was being used before any...
Overly simplified economics. The new widget factory has a construction cost, taxes, and employee cost. Also there is no guarantee the market...
The card looks fantastic and prices are competitive as well. Vega 64 is rumored to perform the same as a 1080 too. The discounts on Ryzen parts is...
All hardware info is in the other thread http://forums.bit-tech.net/showthread.php?t=304130 mentioned in the first post of this thread. Its...
In my last thread I played some games to get an old X58 system up and running near its intended speed. Ironically its been almost a year to the...
You should be able to add Windows to the grub bootloader by simply updating grub from antergos. I'm using a similar setup with Windows and...
Pricing will be the biggest talking point. With the RX480 slightly cheaper than the 1060, I hope there is a vega card to do the same to the 1070....
Mobo's these days look like they belong in an art gallery. Before long people will take custom images to print on PCB's or have design your own...
No need to be jealous of my high(ish) end graphics card (from almost 5 years ago) that can tear through games (from 7 years ago) at maxed out...
Youre welcome. Yes I have played video well above 1920x1080 resolution with no problems. If you are allowed to hang things on the walls I bet you...
The graphics that comes integrated with recent intel i3 and i5 processors is more than enough assuming the motherboard has enough display outputs....
The pascal titan x. I bet people are going to find it difficult to game with their e-peens blocking their 4K 3 monitor setups.
Since the GTX 1060 is going to launch soon I have been looking through the pictures of its non reference boards. Nvidias reference board uses a 6...
This paired with USB type C will make for a potent phone or tablet in the storage area.
