A few more pics to show the relative size next to a classic Chieftec Dragon. [img] [img] [img]
Internals. Cable Mess. [img] Heatsink side. [img]
Neji, not much to show in the internals, but I do have this one that shows the relative size of the board to the case. [img] I'll see if I can...
Completed Project: Hackintosh, Jr. Before I start, I didn't take any pics of this during the build process. I was "in the zone" and decided...
That is not ITX. ITX is 17mm x 17mm, that is 22mm x 19mm and looks proprietary.
Glad I wasn't the only one to see that. I have a wood breadbox in my closet awaiting a date with saw blades and sandpaper myself, but that'll be...
Well, this one is going through some design changes. Switching from the MSI Fuzzy 965/Core2Duo mobile to an Intel DG45FC/E8400. Scary thing is the...
Project: BreadBox Mini We join this mod already in progress.... Some background first. I've built a couple of systems using curved aluminum...
[img] 1982 US Military issue made by Hamilton. Not the greatest watch, 7 jewel movement, spots on the dial, scratches in the crystal, ugly...
They grabbed pics of one of mine, but neglected to include any of the info so it just looks like some underpowered piece of old hardware. It then...
Power supplies are pretty much the biggest issue I have with building small, next to the size of the video card itself. Hard to find a quality...
Portwell PEB-2736, 105mm x 140mm. More expensive, not as small, but should be a better performer and about as good for power usage.
The DVI-D is on the pin header behind the VGA and COM port, so it needs a cable. 10 cm x 7.2 cm, but how much bigger is it with the two boards...
SBC = Single Board Computer, one small board with all the stuff you'd expect on a full-size ATX board. Just think of them as another form factor...
I think I found this one by searching for XP Embedded, but SBC or Single Board Computer will bring them up on Ebay as well. The ones I prefer are...
The aluminum one uses a Commell LS-371 Mobile Core 2 Duo board with a 2GHz T7200. Different class of system, and a way different price range. That...
So far it runs pretty cool, but I will be putting a few vent holes on the bottom and in the handle area. Should be able to get a bit of convection...
My current job is located near a Goodwill thrift store, so I head by there on my lunch break at least once a week. Never know what you'll find,...
Well, I have been working on this, but I seem to have lost a few pics along the way. Figured out that I could do a single layer backplate for...
This board is sold as the Avalue EBM-945GM and the BCM EBC5945GM. Same board, but the picture on the Avalue website is of an earlier version....
