I didn't know it existed for Discord hehe. sorry for the inconvenience.
Sorry. I use google translate but the Portuguese translation is always bad.
DESCULPA A PERGUNTA MAS O PROJETO DE VOTO PARA VENCER NÃO É ESTE ACIMA ?? POR QUE TIVE MAIS VOTOS E NÃO GANHEI?
show Alex mention my project i am a big fan kkkkk
Tks man rsrs.
[MEDIA]
[ATTACH]
[ATTACH] [ATTACH] [ATTACH]
Then everything was set up and here's the result: HOPE YOU LIKE IT [ATTACH] [ATTACH]
After that, I tested it inside the box and when everything worked out I started doing the finishing part. [ATTACH] [ATTACH] [ATTACH] [ATTACH]...
[ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH]
With the plate ready, now I started installing the pieces definitely on the acrylic pieces. For clarification, on the vertical acrylic plate I...
After placing the pipes, I take the measurements from the base to redirect. [ATTACH] [ATTACH] [ATTACH] To redirect the liquid at the bottom I...
When it came to adjusting the positions of the pieces, I did it this way because the pieces are well exposed, at first I wanted to put the font on...
Now that I got the measurements, cut the acrylic on the router and then finish it. [ATTACH] [ATTACH]
I emphasize on empiricism, I do not have much knowledge on the subject. But it worked kkkk. For some reason I don't know, I had to change the...
In the electrical part it was as follows: 1x Arduino uno 1x 24v source 1x digital driver 1x smart socket 1x conversion relay from 120v to 5v From...
[ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH] [ATTACH]
Okay I did my part, I trusted, but my friend project of elevation was not cool. So change plans, let's go back to the original plan. We will spend...
