Overheat? I'd be more worried about it taking off!
The pumps are in series rather than in parallel. Parallel sounds like a much better idea for redundancy but doesn't work as well in practice....
Definitely looking good. You can come and polish up the varnish on my workbench if your arm's still good! ;) If I get it shiny enough, I can...
Now THAT's looking neat. My wife would very much approve! Saying how much is riding on the cables being correct for the first boot and then...
*cough* already ordered :rolleyes: :thumb: Didn't fancy the hundred odd quid for the official one. The new version comes with a header for adding...
I wish to complain about the quality of the work in this project....it's too good and making (some of) the rest of us look bad! My wife also...
Nexxo: Nice, thanks. Looks like I'll be making some tools as a first project then! :-D Andreas: Thanks for that. The logical progression (in...
I've done a fair amount of "just drilling holes" and like everyone (probably) I think I know what I'm doing. Interesting and useful to read...
Floating sounds good. Neoprene also good to not scratch what it's under. Found a hackspace vaguely near me so going to see whether I can get a bit...
Looking good. Interesting to see how you're approaching things - from a problem-solving perspective...that and I've got you to blame for looking...
So at the risk of littering the thread (please tell me if/where there is a better place to take this), if I were to give in to getting a CNC,...
Vault-Tec: Cheers. Shall endeavour to post some useful (or interesting) content while I'm here! Cheapskate: Very true. My metalwork efforts...
When it said "Scratch build" I really wasn't expecting you to be making the tools to make the build! That's taking it to a whole new level....and...
Nice processor for the money! Physics scores will benefit from the extra cores - it's a workload that scales out quite nicely. Decent amount of...
Its surely designed to make it look nice from the side you can see stuff from. You could spend hours days making the wiring look obsessively...
Pretty much anywhere you can fit it - and I appreciate space is tight. The loop temp will equalise so where you read the temp makes little...
Thought I may have to do something like that for my machine to let some air into the PSU. New case has it floor-mounted and with the vent facing...
Looking really good painted. Clearcoat should really finish it off...that and some hardware inside it of course ;)
It would make it harder to get the tubing on - although warming it in hot water may solve that. It would probably reduce the efficacy of the barb...
