Cant really see the point in this. If you want simple.... go the corsair or other closed loop route. If you want flexibility.... go the full...
Have you overclocked your 8400? If not, that can easily do 4ghz+ with even average cooling. Pushing your current setup might be your first...
Comments from people like Tim Sweeney are reasons why I am not upgrading my current gaming rig. If there isn't going to be any software to...
Hey folks, Was hoping I could pick the brains of you wonderful and knowledgeable lot :hehe: Would anyone happen to know if I can use the...
It's gonna be useless for watercooling just like the Scan's Scorpion X which uses Silverstones FT02B. You need the hot air to go out of the...
Personally, I'd buy a Intel 6300 Ultimate card that supports triple stream 450mbps. Then go on ebay to buy a mini pcie to pcie adapter for a...
I personally think you should hunt around for a secondhand 480. Ebay is your friend here as you'll occasionally see them on there with...
With i7's replacement coming out sometime soon-ish, makes you wonder why anyone would... I'm still happy with my P6T Deluxe V2!
Same here... :( Tried posting, but I couldn't even post let alone vote on this thread...
Or... pick up a cheap 2nd hand 5850, as there are loads kicking around auction sites and other forums. Just depends on how much you wanna spend...
Scythe Gentle Typhoons 1450 here! Had the Sharkoon Silent Eagle 1000s and they're great fans, but the Typhoon 1450s are even better. They push...
Galaxy S if you can get one cheap. Best phone I've used so far. Great portable media player as it supports every format under the sun (MKV and...
If you're gonna bring all the stuff back yourself, you're gonna have to dump all the boxes and pray to the overclocking gods that the guys in...
Personally, I'd go for the 570, and find the cheapest one you can find. You'll find that the reference cooler on the standard ones is pretty...
Great system. Makes me want to rebuild mine now...... ARGH!
These are awesome. Well worth the money. Wish I read your review before I played with mine... got mine stuck too (oooerrrr!!) and had to get...
TJ07 if you plan to do some watercooling. Would even be worthwhile if you just watercooled your graphics as most reviews have pointed out that CPU...
I'd just personally go for the cheapest one as most of them are the same. Only diff to look out for is tiny overclock coupled with a revised...
I'd gun for the 570. Did a lot of digging as I was in a similar position and I'd go for this option, with the possibility of SLI later if your...
Based on that info, I'd gun for the 570. Did a lot of digging as I was in a similar position and I'd go for this option, with the possibility...
