Hi bit-tech, just been contemplating what to upgrade my PC with. Had it for a few years now and it's starting to show its age with Star Wars...
So I recently got a new motherboard: AsRock Z77 Extreme4 (it has EXTREME in the name so it must be good!). I've kept the i5 2500k and the EVGA...
Problem solved :) Motherboard issue. Replaced the motherboard and haven't had issues since!
Tried memtest, no problems with the RAM. Tried reinstalling Windows, still crashed after some time. Anybody got any advice?
Thanks for your input :) Thanks! :D I'll definitely do both. Thanks for the input. Budget won't be a problem for just those 2 things I...
I've checked to see if I had any overclocks. My CPU hadn't been overclocked. My GPU had an overclock at one point using EVGA Precision, but I took...
Good advice. Glancing at prices from amazon, the difference between the two GPUs is about £60. How much of a difference is there between the...
I did do a clean sweep of the GPU driver but that didn't solve the issue. I didn't try the Audio driver though, so I'll try that out the next time...
Thanks for the advice. Any personal recommendations for the GPU and SSD department? They DO look amazing! The doors, size, handles... I want one...
Would the boot files not being on the SSD also cause the system to crash randomly all of a sudden? Also... I won't lie but I have little...
My current build is in my signature and has encountered issues (posted a thread in Tech Support, hopefully someone has a solution) but it's got me...
Just to spark a debate, what are people's general experiences of compression fittings vs barbs for their water cooling kits? Been watching some...
Sorry to hi-jack, but to me the general theme here is to treat your coolant like you treat your teeth- check up on it every 6 months with the...
That makes sense. So you secure the sponge to the case (with the screws) and then you can velcro the pump to the sponge? Or use the Force...
Could you elaborate on "one of those sponge things"? :) I'm a complete noob so this is new to me. I always thought of things as being screwed...
Just a quick question: Where do people commonly put the pump for their watercooling kit inside their case? I've read some reviews and...
So where would be the cheapest place to get Titanfall from? Amazon? Origin?
The Batman Arkham series will definitely appeal to you as you get to be the f***ing Batman!!! Also, if not mentioned, the latest Tomb Raider...
Reached Diamond V personally a few days ago before my PC started having issues.
Being a massive Sonic fan, I'd hate to say Sonic The Hedgehog 2006. The game was just not finished but still released. I was appalled that it was...
