I will cling to Media Center until it literally will not run any more.
OK, well, this is disappointing..... According to the tech. specs the 6i5 and the 6i3 will still have PCIe x4 version 2.0 M.2 slots....
As a daily user of Windows Media Center, I am interested to know if a copy of Win 7 can be loaded onto a PCIe 3.0 X4 M.2 SSD (like the Samsung...
Too bad it only has GPRS. It should have EDGE or HSDPA or UMTS or something a little better. Then it might be worth the hefty price tag with...
IE7 is STILL not fully W3C compliant. I have developed a few pages recently, and IE7 SUCKS when it comes to CSS. Firefox all the way.
Thanks to the Auzentech having an onboard connector for the "Hoontech" (which, as you may recall is an SPDIF daughter board for the SB Live!...
SPDIF Audio and HDMI??? One thing that confuses me about the integrated audio in the ATI/AMD cards is how they react to other audio cards in the...
http://www.bit-tech.net/news/2007/03/15/sandisk_shows_of_2_5_32gb_ssd/ OK, $400 (ish - not really sure of the exchange rate) is a lot more...
I'm building a Mini-ITX system, and I want a small hard drive. I don't need massive storage. I've heard of people using CF cards as hard...
As an HTPC user, I am a big fan of that slot loading Blu-Ray drive. I've been trying to find an HD-DVD drive just like it, but nothing yet....
I recently picked up an AuzenTech XPlosion 7.1. It has the C-Media CMI8770 which is also a Dolby Live/DTS Connect chip. I really like it. This...
I forgot I posted this so long ago. Since then, I have gotten the AuzenTech XPlosion 7.1 sound card with the CMI 8770 chip (from Newegg). I...
Whoah, this is huge. I had never considered that HD videos on Blu-Rays or HD-DVDs would be HDCP protected. This makes sense, but SUCKS considering...
AMEN!!! Couldn't have hit the nail on the head more precise and accurate. This is in my living room, not a "game cave". Hacking and glueing is...
Personally, I hate HDMI. I have one on the back of my Epson Cinema 550, and it flops all over the place. You need to support the cable a few...
Yes, but still haven't gotten their act together for us digital lovers. All this EAX surround BS only works if you are hooked up to the amp via...
I retract what I said.... Well, the new power supply with foil had good reception. Just imagine what the old power supply with foil would do. So,...
Problem Solved! (sort of) I figured it was EMC, or RFI or whatever you want to call it. I mounted the PS outside the computer, with no...
Hello all, last week the computer crapped out on me while I was watching TV. I have a MyHD digital tuner card and a projector (100" screen :D )...
Hi, I would please like to know if anyone sells a power button that looks like this (in the lower right hand corner of the pic): [IMG] If...
