Hello Again! I'll bet all 4 people following this build are wondering where it has gotten to... Well I have been using it as my main PC at home...
Finally a update! I got the wallplate finished... [IMG] [IMG] [IMG] [IMG] Tested it with my handy dandy tester.. [IMG] [IMG] Shot...
So the Epoxy is all set. I decided to shape it up a bit. [IMG] So I sanded, And sanded some more... [IMG] Then I scuffed and cleaned both sides...
Nice another Lowfat dual proc build!
OK, so a whole month has gone by and I finally got some time to work on the mod. And I may have slowed down on the modding but the mess kept...
Epic
Yeah! I like mine. Fixing to add a 3rd one. Plenty of power in fact its almost overkill for 1080 I like the color you picked too.
Nice a Build with GTX 680's I feel relevant again. XD Can't wait to see whats up your sleeve this time!
Where did you get the 10-32 Drill/Tap? I found a Greenlee on Amazon for 10 bucks, But that seems pricey
Something wicked this way comes!
OK, I didn't finish the 24 pin yet... Its about half done... But progress must continue. After I spent so much time on the vanity plates to...
Yeah, thats the one thing I wish this board had is a second 4 pin fan plug. My MSI Z97 that i'm using wile this system is down has 2 fan ports thou.
After looking at this backplate for a day or two I think I'm going to pull it off and paint it. Its just to much shiney!
:rock: Love it
Welcome back guys. been a couple of busy weeks, but I did get a little more done. I got the clip mounted for the front panel wires and remounted...
If your like me you feel good when you finally find a use for a little modding goodie you have been saving for awile.. Cool little switches
Ah, A low powered web machine with some EEL zip... I gotta see this.
Awesome... /speechless
This is awesome... i shared a link to this log on my facebook. Hope you don't mind
Ok, time for a update. I worked about 72 hours last week and then had to spend a whole day working on my truck... Yay fords! Anyhow I did get a...
