What router do you currently have? If it's an Asus you could get a second Asus router (plenty on eBay) and use it to create an AiMesh network....
After considering all the feedback in this thread and some research, I reckon the R7 makes more sense for me. If I need more airflow I can just...
The lead on the external card reader is very short and I've found that using a longer lead doesn't work, so that'd mean I'd have an external card...
The internal card reader is an Akasa USB3 one, though it's designed to fit in a 3.5" floppy drive bay so if I re-use it I'll need a 5.25" adapter...
The cooler will most likely be a Noctua
I've since read another post in these forums that made a good argument for just using an external card reader (I already have a USB3 one for my...
I'm speccing a case for an i7 or Ryzen 3900X-based system that'll possibly be OC'ed to run between 4.5 and 5Ghz so good cooling is a must, but it...
How do they compare this case with the Define R6 which isn’t even listed in the thermal performance tables?
I discovered that my SP4's main drive came BitLocker encrypted and when I checked the recovery key and printed it, I found that the machine ID...
Thanks, much appreciated :)
I tried both those options but the installer says that the OS is incompatible and exits.
I've upgraded from Win7 to Win10 but there's no Asus TurboV application that I can find will install to Windows 10. Is there a Windows 10 version...
How many routers have a WAN port that's faster than 100Mb/s? For those lucky enough to have FTTC, G.FAST will only serve as an upgrade of...
Done all that. As I said I've tried it with 32 bit WinXP and it works. Tried it with Win 7 32 bit and it works. What I really need is another Win7...
I've tried with both and with different leads, but I primarily use it with USB3
I have one of these Aaka DouDock S 3.5"/2.5" sata disk caddy which works fine in Windows XP but not so good in Windows 7 64 bit: when a disk is...
Just to finish of this thread, I've installed the RAM, I now have 12GB of 1600Mhz 9-9-9-24 Cosrsair XMS3 of memory and it all works fine, despite...
I've found that a VM hosting a 64-bit Win 7 guest OS with 3GB allocated RAM maxes out my system's physical RAM, so I'm hoping doubling up my RAM...
VMs are my main reason for the memory upgrade so it's good to see you say that 12gb is enough, otherwise I'd have to go for 24gb if I needed more...
@Roosauce: Just looked at your system spec - wow. What do you use it for?
