It is a A7V-VM. Sorry for the late response.
I will check it when I get home from work tonight and post the make and model of the board.
I need help on either changing or updating the bios on my computer. I would like to over clock but I cannot chnage my FSB or multiplier. I have...
dex: I don't think you have a problem with organizing, more with keeping things organized. seems like you need another harddrive than a beter way...
My roomate slipped some acid into his english teachers coffee one day. After repeatedly trying to write on the board she ended up huddled in her...
I work as a Graphic Designer for The Canadian Military. not as great as it first sounded where I'm based ATM. I pretty much make posters for base...
is that bottom space like another compartment or am I just seeing the images wrong? how about keeping the different components in different...
this is all as stupid as extreme political correctness is. everything blown way out of proportion. everyone thinking to themselves, if I don't do...
you can save alot of space if your not too picky about sound. mono @ 24000khz is good but I do mine at 11000khz, mainly because I have crappy...
So not making a weapon (non-leathal at that) because it could be used for torture? ummm its not hard to torture people. its been pretty well...
that tanker would look pretty sexy! Did you ever put any thought into putting the PSU in the other trailer? It would prob save on heat and space....
It would be neat to have some kind of metalic partical swirling in the water so you can see the effect better, or from farther away. but I can't...
from the image gallery that looks pretty damn cool. to bad I'm at work and the images are the only thing that shows up n our crippled network....
good thing I type slow that was a bit more to the point. I was pretty sure that the NTSC/PAL thing was more of an analog issue, they were...
for the NTSC/PAL thing I'm pretty sure the xbox would work fine if you get an adapter to plug it in, and the NTSC games would work fine, PAL games...
funny... my second button works the same in osx as it does in XP. maybe its a user problem.
I would run with an avid/protools rig then. Cruise thier sites and see what combination works for you. then build the machine to the specs for the...
what programs do you want to use. an avid/media 100 type thing or something like final cut pro? If its final cut then checkout the apple store...
I'm having a sudden urge to consider a career change. There has to be something incredibly satisfying about having metal submit to your will and...
breaking it up into smaller pieces isn't going to help even if it does all burn up. what would it be burning? our atmosphere. that much happening...
