This is the best case ever. I will not eat for a month to buy it. Seriously. Do you plan on selling some sort of bag (soft case) for this...
Hey guys, it's high time to introduce you to my new project. It's based on X90 Aquarius PC Case made by SilentiumPC company. The case was reviewed...
This project is finished! Specs: Motherboard: Asus P8p67 EVO CPU: Intel i5-3570k RAM: ADATA Pc3-12800 2x 4Gb PSU: Silentium PC Deus M1 550W SSDs:...
Thanks Guys! But brace yourselfes, the end is near! Back of the case with PSU mounting and cover for motherboard I/O ports and VC. That 4 holes...
I couldn't make up my mind how to paint the veneer, after a couple days of thinking I decided to go with half-matt clear varnish. Must say that...
Thanks guys, I'm glad you like it:) It's been a while but here's next update. I'm going to get down to work on the case and if I'm lucky I will...
ups, sorry for double post, my internet connection gone crazy :P
While I was mounting the water block on the mainboard I thought to myself that it looks kinda...naked without that third heat sink. So I cut the...
Sorry guys for keeping you waiting, there was quite a long break, but don't you think that I haven't done anything :) [img] EK Water Blocks...
Just received delivery from ADATA, which kindly decided to support me with SSD and RAM. SSD Premier Pro SP900 128GB [IMG] XPG 2x4Gb PC3-12800...
yeah, basically you can't do this but it doesn't really matter if you're only evening the edges :) I don't really know about the shear because...
Thanks! It seems that everyone like these gifs:) Basically, the case itself is now made. Have to make vets and a window but this has to wait...
Looks grate mate but if I were you I think I'd use a smaller rad and put it inside the case.
That's a short update this time, but I'm quite far with building the case. Only a matter of time when I post it, should be soon. Having the mobo...
Thanks! Hope you won't be disappointed with the outcome:) To safe some time I decided to use a mobo tray from my old case. [IMG] [IMG] And it's...
final pics: http://forums.bit-tech.net/showpost.php?p=3488201&postcount=33 Hi :) I finally started new project, I hope you'll like it :)...
How did you bend it? Brake press?
I can see the pics in Poland, and they're awesome :) Great design.
Don't you think that such placing of the radiator makes impossible to use longer graphics card? Almost every good graphics card is longer then itx...
Thanks guys! I really appreciate it :) Well it is quite heavy, fully equipped weighs about 25kgs/55lbs. Anyway, I don't move my computer at all....
