For these low profile coolers I'd love to see a matrix of which cooler fits which mITX board and Chassis as it can be a minefield when clearances...
Last time I worked I am a semiconductor fab and transistor design was during the 90nm node transition so I may be a little out of touch. Something...
When's the pink version out?
Can't wait to see the finished article in the flesh.
Who thought red fans and a blue window was a good combination?
Rule out anything with AMD, Intel NVIDIA splash screens or PhysX You need to use more than three games to spot AMD or NVIDIA bias. Don't be...
Hitlers take on the situation: http://www.youtube.com/watch?v=QFqxn804Vmk
http://www.gigabyte.com/press-center/news-page.aspx?nid=984
I heard that ASUS will shortly announce full blown product recall.
You should only be able to skip a cut-scene once you've been through it. But games should avoid repetition of stock animations.
Nah, it was the #LibDemFlashmob
Crosshair 4 Extreme
I'd vote CURE in Brighton, anywhere else Lib-Dem #geekthevote
April 27th, Thuban aka Phenom II x6 1055T and 1090T launch, if I was buying around now I'd be looking at AM2/3 rather than 1156.
Still hard to beat an X4 B50 for value.
CustomPCs very own Ben Hardwidge has been getting busy 6.3GHz on LN2 no 230MHz wall there.
M4A78LT-M LE: unlocks 550, runs and overclocks 1055T, probably unlock 960T too.
The 4GHz and 4.2GHz result is suspiciously similar, but it features a 790FX not 890 which is where these CPUs should really shine. Someone on...
Can you post the scaling factor with the Cinebench data? From what I've seen Hyper-Threading helps keep it linear as core count increases but...
ASUS have released BIOS updates for their full range of AM2+ and AM3 boards, even the nVidia variants. AM2 might be asking too much. Please be...
