wrong item, but i found what i wanted on the site click. It's going to cost like €22 which is about £16 GBP. Bit to much for me to pay out.
Does anyone know if you can buy UV PCI-Express plugs in glow/little green in the UK? i only know of one site that seems to sell plugs and they...
I'm about to fit my PC into a new case, so i think it's time for some cable sleeving. I've just got a Eclipse 62 (black) and a side window panel...
top work :rock: like the clean lines and the colour of the case :)
Has anyone got a link to a memory clock tool? i used one before that would let you change the timings and 1T/2T in Windows, but i've lost the...
one last thing how do i code a login block from my home page to phpbb forum?
i got your way working, so i'll stick with that and recode it if it gets to big like you said :) thanks for the help :)
i think i get it now, so i make one folder to put all the main pages and other folders to drag files from that are used on the main pages e.g....
here you go:
changed that coding but i've got this error
you have just all lost me :(. Is there a guide that will show me how to do it an easy way? Here is the code for the home page and the code for the...
i've just checked on the XFX forums and can't see any bios updates :( does anyone know where i can get one from and the best flash utility?
I'm having probelms with my 2 XFX 6800 GT's running in sli when i boot up. They are both the same card and rev 1. Is there away i can check if...
anyone? i really need to fix this or i have no sli :(
do i need to do any thing to <?php include('content.php'); ?></div> also do i...
i'm lost now :( here is my code: <html> <head> <link rel="stylesheet" type="text/css" href="style.css"/> <title>:: Half Review :: For all...
ya, but i don't want to use static frames if that's what you are going to say :P p.s. ya, sorry
i couldn't really tell you, they are both V1 cards, but i haven't tried to flash the bios as i don't know where to get them from for the card.
I'm making a new website with 5 PHP Incs and i was wondering if you click on a link is there away that only the middle include will change to...
right, i've fixed the boot up problem by changing the cards around, but now when i go into windows it says that SLI has been disabled and it...
