This is just an overclocked 785g board so no full HD audio with PAP so it has to have a 5*** series card to pass thru full HD audio
Even though its an asus I'll still buy one on release day.................unless Gigabyte release similar At last a true HTPC board that will...
Finally the dream might come true............an always on HTPC that is economical to use 24/7/365 and is more than powerful enough to run bloooray...
I'm in love ..............or is that lust :naughty: A nice sharp side cutter will fix all those unnecessarily long tails :thumb:
At last a little competition so hopefully the HD5850 price lowers a little = buy
Its a 'MAYBE' buy if it came without a PSU but having to buy the case and PSU as one bundle is a deal breaker for me
So whats the going rate these days for an nV shill ??? :rolleyes: If the 460 really does use GDDR5 then why is it clocked so low, the bus not...
Why dont they use GDDR5 for higher performance ???
^ Haha well that was good timing :D Wouldn't want to change jobs before you finish with all the tools :hehe: Good luck with the new...
^ Its a great challenge and even though I personally would go the m-atx route (I have m-itx, m-atx and atx builds) if I was thinking of doing...
The thought of using a PCIe splitter to get two x8 speed sockets defeats the whole purpose of using an itx board Why would you and what itx case...
The Giga miniITX H55N USB3 has been benched @ over 5.0GHz by dinos22 and youngpro, check it out @ XS
10 inch should be the very max screen size
And who do nubs ALWAYS blame when they cannot OC like the big boys............... :eyebrow:
My main rig uses a DK P45 T2RS Plus and its been an amazing board from day one I really hope this is not the end for DFI
Not wanting to sound like an AMD apologist but I can tell you with all seriousness that 95% of ppl would not know the difference if they are using...
I've been waiting for this for too long now and its getting hard not to look @ an Intel m-itx solution using the h55 chipset and i3 CPU Please...
But where are you going to source a slot load slim BD player to fit into your piece if art err I mean m-itx build ???
That pink 'thermal' goo (as in its 'kin useless) is the work of the devil
The problem with DDR3 lower voltages is a bit of a joke ATM as dram suppliers are using old tech with low grade so DDR3 is sometimes using just as...
