I'm a convert to the separate numpad. So much more flexibility. I actually have it behind my keyboard at the moment :lol:
3 out of 4 is easy but I think you'll struggle to get Display Port and VGA on the same card in actual port form. That said, I really wouldn't...
My tip for finding the "actual" dimensions for something that doesn't really exist is to look for something that would be a fairly standard size...
If you know/work out roughly how big something should be in real life you should be able to scale the model to fit your needs before printing...
[MEDIA]
[IMG]
It's one of these situations that seem to crop up surprising regularly where it would be so easy to be heavily *inspired by* the original work to...
Yep, depending on space and money it can definitely make it worth it just for that one time it saves your bacon... I sometimes use it for small...
I'm a flatbed convert. It does make things a lot neater.
I remember back in the days before they started skimping on fresh air I order to save fuel you could fart with impunity and rely on the...
https://www.patreon.com/posts/patsy-is-here-46453580?utm_medium=clipboard_copy&utm_source=copy_to_clipboard&utm_campaign=postshare
As someone who plays both pool and snooker, they're both as hard to play as the person you're playing against is good. Great pool players are...
I read between the lines and assumed something along the lines was the case :happy: If this was for a bit tech user themselves I might well have...
Seems like NZXT have done the right thing, albeit a post fallout decision always takes the edge off. [MEDIA]
Probably the sort of thing Jeff Goldblum used to deliver the virus to the alien mothership in Independence Day.
If the issue is something as serious as a fire hazard you can't rely on the fix being using non-conductive screws of a specific size, and also...
The problem is this: ...when you're just tossing it around as just an alternative viewpoint/opinion. Without being more specific it's potentially...
Pretty much very single expert I've heard has said pretty categorically that the speed with which vaccines have been produced has been down to the...
Brexit thread or Coronavirus thread? [MEDIA] Or maybe just merge the two into a general current s**tshow thread?... *sigh*
