:clap: Yes - please write a diagram over it. Good job! :clap:
Hi, Running my PSOne on a RAEON7000 (Secondary) and my main 19" on a RADEON 9700Pro. At the moment I'm using CAT 5.11 and it all workes. When...
Mine is little dark even if I adjust the brightnes to highest. I'm willing to try it but does anyone know how the capacitors should be connected?...
I found this info on the web NEW! [Jan 12/99]: You must add a 220uf capacitor in each of the RGB lines to get an acceptable picture. If you...
I didn't have any problems with PowerStrip 3.30 buildt 366 and my Radeon 7000 PCi, the card is without fan, only heatsink. I don't know what other...
I guess it will never detect your PS1 as a secondary monitor. I recomend you to get a second card, then it will not be any problems for windows to...
Yep, I first tried with my 9700 Pro, but I'd to do the hot swap thing 2, so therefor I went out and bought a second card, just for the PS1 LCD so...
I'm using 2 Graphic card, Main (Radeon 9700 Pro) is for my 17" LCD, and the second one is just for the 5" LCD (Radeon 7000 PCI). So I guess you...
I bought a second Graphic card (Radeon 7000 PCI), don't know if there is any mod to make so it will autodetect the LCD on your main Graphic....
Here is a pict, hope it helps. Some wire are stil left when I tried different wires (it look like sh** right now). I'll use a PsOne Cable that...
It's look like you have got a Thrustmaster LCD, I've got mine working, see my post. http://forums.bit-tech.net/showthread.php?t=103008...
I'm using M pro's Cable Layout and with the RGB ground to LCD pin 7. And it's hooked up to my second card (Radeon 7000 PCI). [IMG] Here...
:thumb: :thumb: Yep, I like it - Clean and Sexy!!
:rock: :rock: Finaly I've got it, I'm happy with the picture on my lcd now. [IMG] And Nexxo's Samurize is :thumb: , have to install my...
I've got a steady picture now, but I need some help on what I should try to adjust, still some distortion at the top. [IMG] Cheers
I'm almost there... after some more hours. The picture is not 100% steady and it's "jumping" up and down little, and on the top it's more...
Thanks Nexxo for your answer. Wonder if it could be the cable or maybe I should try with another version of PowerStrip. I'm running ouf...
So I can't run my main screen in 1280x1024 with the 5" LCD at 640x480? Do I've to set my main to 1024x768? Cheers.
I've got some picture after spending hours with PowerStrip. But I have problems to resize the picture in vertical (it's to big), anyone know or...
