"shuttle gets show down over LA" - Should this read "shuttle gets shot down over LA"? Not a huge fan of shooters on my iPhone but might give...
I've had a go with that and I just get the power led coming on for the same period and then going out. I'm thinking from the "popping" noise...
Hi All, My girlfriends NEC I-Select laptop has just died. She says it turned off suddenly with what might have been a "popping" noise... Now...
Well, new problem! When I try to format the drive it will progress fine untill the very end when I get the BSOD. Happens with Quick format and a...
No luck with any of the above suggestions so I've bitten the bullet and formatted the drive, hopefully it'll work once that's finished!
No luck with the Ubuntu live cd, drive didn't show up at all... Looks like I'm going to have to format it and see if it works (bummer!) Any...
The hard drive can be heard to spin up and the activity light works on the USB enclosure that it's currently in. Will have a go with Ubuntu...
I've now got the drive plugged into a USB enclosure and windows does recognise it. Problem is there's no way of getting to the files, the drive...
I'll have a go with a USB enclosure tomorrow to see if that works... Cheers I've just run SeaTools on the drive and it passes the Short Generic...
Hi Guys, Got a weird little problem that I could use some help with. Basically I've got a 200gb Seagate IDE HDD that I use to keep my music and...
What an awesome looking machine! One thing though, should "Violin-style sound holds disguise cloth-covered speaker grilles" read as Violin-style...
It's just round the corner from where I live at the moment and I've never seen it! Bad luck mate, that looks pretty horrific.
In the end I decided to go for a fresh install of XP to cure a couple of other issues and it's working fine now. Thanks for all your help...
I can rule out the IDE connectors on the motherboard as the DVD drive works fine on either channel. The cable is brand new out of the motherboard...
Sorry, just to clarify. The 250gb Drive is the master and has the XP install on it. The 200gb drive that is causing the problems is connected...
Hi All, I've just bought a second hand computer: CPU Type DualCore AMD Athlon 64 X2, 2200 MHz (11 x 200) 4200+ Motherboard WinFast...
I've come across the following system: Asus A8v Motherboard for AMD socket 939 Processors 2x 512mb PC3200 400mhz Ram AMD 64bit Athlon 3200+ CPU...
No dual processors here, just a 2800+ running a standard clock speed so no massive power requirements! The only reason I need a new PSU is because...
Thanks bbq. Anyone got any suggestions? I'd like something that will be good for an upgrade in the future if possible! Budget of around £30-45....
Hi Guys, Running out of power slightly in my system so I'm looking for a new power supply. This one (an Antec Smartpower II 500w) sounds...
