I saw the video too! That looks great! I'm also planning to do a few mods to the use using some exotic materials, but I dont have the tools for...
Hi Bill! I just saw your parts on your website and they're amazing! My case feet is just a copy from the original but its made out of aluminium!
Hi Bill! Yes they're 6/32!
Nice work! Can you tell me which program did you used to create the model?
Hi guys! I want to introduce you my latest mod. Back in august Asrock and Qnap asked me if I want to make a mod for them. It wasnt a hard choice...
Hey guys! After my CaseLAbs S3 Matx mod I started a new build into a IN WIN H-Frame Mini. I made this mod to my girlfriend for Valentine's day....
Yes, they're so big, but the build quality and the case is amazing. Originally I wanted an EATX conversion, but in that case the normal atx psu...
Thanks. I use this 1600w because i got it really cheap as b-stock :)
Hey Guys! My S3 mod is FINISHED! You can see how the new back came up. Its the same size as the original, just with matx support. If I want I can...
Edited!
Hi guys! I started a new mod into a CaseLabs S3 . I've never seen somebody who did this, so let me show you my worklog about the modification and...
Final UPDATE! The system is done. You can see the builing progress on the pics and last you can find the finished rig. [img] [img] [img] [img]...
Update! I've just finished the case. The last step is to install the hardware which will happen soon. So here is the finished case: [img] [img]...
Update! Got most of the new hardware. Asrock X99e itx i7 5960X 2x8GB Crucuail Sport Crucial 240GB M500 [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]...
Little teaser: [img] [img]
Update! Almost finished with the painting. The last step is the polishing. It will be done soon! Also you can check out the new case feets which...
Im gonna use cable combs everywhere. There is no need to install them to the other side because they'll be hidden anyway, If i instal them to the...
Yes theyre attached with welded pins. Im gonna install them with screws. To install them with screws i need to drill some holes and insert some...
UPDATE! New side panels arrived! Ive just started to attach them to the case, also im started the sanding on the frame and prepare it to paint....
Update! We are finished the new panel designs. Here is some teaser. [IMG] [IMG] [IMG]
