If your system is running fine then I wouldn't upgrade. I believe outside of targeted benchmarking you're unlikely to notice any speed reduction...
In my experience you can just plug new ones in and they should find the network irrespective of brand or rating. You may need to sync the new ones...
I believe the 1070 TI launched at £420 so it's better than many that's for sure. They overclock well and I've heard you can exceed stock 1080...
I would be wary of replacing a 780 with a 1050 TI as that card has virtually the same performance as a GTX 680 which is a solid step down from a...
:confused: I'm not up to date with the current specifics of lightroom/photoshop/illustrator but here are my thoughts as rough guide until someone...
Orcs Must Die 2 (double pack) for £10 Orcs Must Die 2 (single game) £5.98 Orcs Must Die 2 Complete Pack (inc 2x DLC) £7.50 :thumb: Two...
:rock: I'd suggest primarily focusing on the gfx chip as this is likely to be the most limiting factor in gaming performance, esp in a laptop....
:worried: Never played any of them but £10 for the Deus Ex GOTY, Invisible War and Human Revolution +packs seems very reasonable. I remember...
:D 4850 5750 6750 7750 9800gtx gts250 gts450 4870 5770 5830 6770 gtx260/275/280 gtx460 gtx550TI. These are all very good cards which may now be...
:confused: It's a judgement call. These pre-releases are usually stable but generally not recommended for your primary system and you would only...
;) Some good info on the gfx hardware HERE. Some kind of REVIEW and HERE. I would heavily suggest checking out On Demand Game Streaming (Onlive)...
:worried: I would say a 5450 would be a decent upgrade over the built-in GF7100 BUT would still be unlikely to be worth it and the x1 slot could...
:) You download the install file or disc image from Microsoft and you can then install it and use it until 15th January 2013 after which you will...
:thumb: A voice of experience there and I'd suggest exactly the same. Perhaps the only other consideration might be if the portability of a laptop...
:thumb: 5450 isn't a higher-end part so shouldn't really be affected much at all. Even a fast card like the 5870/6870 seem to lose around 10% at...
:thumb: If you can afford it pretty much any K CPU is worth it as they tend to have mounds of o/c'ing headroom, perhaps SB a little better than IB...
£34 Intel Celeron Dual Core G530 Sandybridge Core, Socket 1155, 2.4GHz, 2MB Cache, 65W, Retail £45 Intel Pentium G620, S 1155, Dual Core...
:thumb: As said don't pay over the odds for a 775 quad as a 3ghz i3 would generally give better performance and halve the cost of a RAM upgrade...
:thumb: If it was for me I would definitely go for the CPU. SLI has come a long way but as already said doesn't give uniform improvements and can...
:worried: Shogun 2 is one of Steam's 'pretend' sales, available cheap many other places ... £9.47 Amazon £9.97 Currys £9.99...
