Does anybody know if there is a RJ45 single face plate where you can put an RJ45 cable in to the back of it that is already crimped instead of...
Hi, I'm after a cheap digital camera (around £50) I'm not a photographer and the camera will be used to takes pictures of stuff that I have for...
Does anyone have any recommendations for a cheapish Sat Nav for use on a motorbike, motorbike specific satnavs seem a lot more expensive and not...
I've got some .MOV files (Video: 720P HD H.264/AVC1 video codec, 1280 x 720 30fps .mov) that need cropping (only need certain bits of video),...
Hi guys, long time since I've posted a question on here! Does anyone use a Windows front end GUI for rsync? Or a simple way to copy files from...
Computer powers on but doesn't post, keeps restarting! I've just built a new machine come to turn it on.. it powers on but doesn't POST. It...
Hit a brick wall (:wallbash:) Just wondering if any of you guys are using VoIP apps on your iDevices, I've got an account with sipgate and I'm...
I used to have a fan on my side panel but this case now houses a file server and it isn't needed. I was looking for some mesh / a covering just...
I think i've narrowed it down to two. A second case for my home server. It will have 3 hard drives, the rest is your standard PC set up. The...
The last time I was looking for a PSU was when the Corsair 400WCX was the favourite around. (Lower end). The time has come again, just...
N/A
