Please sign this petition to remove the feminist game hating, man hating Anita Sarkeesian from the DEVELOPMENT of Mirror's Edge 2. I have no idea...
My face muscles.
Them temps are fine. 75C for a 4GHz OC is pretty good i'd say. Remember that the i7s have a really high max temp so 75C ain't to shabby.
I've seen a lot of monitors in my time, not a single one beats this for picture quality....
You get free postage from Bit_tech + Scan m8
This is about the best board you can get, with SLI/Xfire. On your budget anyway....
I love Samsung monitors so i just got this one, its on a fresh install atm so can't give full info on it. So far this monitor is Very nice,...
Its a really good mobo, high-end. I doubt a lot of people will like the army camo look though. :)...
Or you could just get a G15, G510 or G19 Logi keyboard.
Years ago now, i got a brand new mobo and decided to update the bios before i even installed the OS. Flashing with the old Floppy method, anyway...
12.5p Man your getting ripped off. I only pay 11p for mine :)
Nah it is wrong though with all the software i have used, so i'll just buy a controller. [IMG]
I've pulled it out now cause it was doing my head in. The mobo is a GA-MA770T UD3P. All the software i have used gets the fans and temps wrong....
Last month i ordered something from Scan and got a free 92mm 4pin fan with the order. Seeing as there was room in the front of my case i decided...
Be careful though, cause now you have lost the temp sensor, well cores anyway. I have a 555 that clocks to 4GHz stable as a dual and 3.8 as a...
Like i said its a strange one. I payed for XMS3 TW3X4G1333C9DHX which have the silver DHX heatsinks. I think theres more to it than just wrong...
How come Everest, cpu-z and other software pick them up as Dominators as well then? Module Name Corsair Dominator CM3X2G1333C9D I can't even...
I just got 4GB(2x2) of Corsair Dominators (1333) from Scan for 60 quid. Now thats a good price :) It doesn't say they are Dominators on this...
Well i've just located the noise and its not the mobo after all. Its coming from the PSU, an old Hyper-R 580w. Its about 4 years old and after...
I will see if i have something to use, seems this is pretty common these days.
