hehe, I just took off the fan and am running just fine, however I have some airflow in the front of my shuttle. Whatever you can find for Zalman...
Well I do not agree, some mods have risks involved. For example, in order to fit the atx psu in my shuttle, the psu now sits without a full...
I dont like the idea of copying someone elses work, or doing a copycat mod. All of those Half life 2 mods that were made were one thing, they...
http://forums.sudhian.com/categories.cfm?catid=46&forumid=1 is a good place to go, we do shuttle watercooling over there, check it out
watercooling a sn26p is a little tricky due to the psu that is locked in place, but it is possible, as big sturl said, your best bet is to mount a...
dont forget about your cable fan grill, and the thing you do with your logo screws, also if you do that light thing on the middle of the fan you...
I can't recall seeing anyone else do it, so I will say these are firsts. They can all be seen in my 500w Shuttle project log. I managed to fit...
I modded my psu quite a bit, and had some of the wires shorting left and right, took me a day to figure out why my computer would randomly shut...
I would just buy a good 1gb stick to start with, I have been eyeballing the pc5000 1gb ballistics
Go in and manually set everything. My system can run medium fairly easy so yours should be good for a lot of things turned up.
This makes me glad I switched over to downloading all my music. I think it is wrong that they do that, it makes me wonder how long it will be...
too slow and you will be wasting time, too fast and it will melt. You can run it on medium and do small sections at a time (to let it cool down)...
Got to love it, hey I notice you have a second shuttle, are you doing anything with that? Can I copy your idea for the port on the flap that...
the fx-60 is a dual core proc and you know it
my mcp350 moves a very small bit of air, nothing you can use though.
I wonder what the lifespan is for a card that runs that fast.
A 7800gtx will work just fine in the smaller st20g5 (I think it even looks better then the sn25p) If you hold off I bet shuttle will be making...
BigZ, my 6800gt is running at 446mhz/1250mhz, so its a little bit more then a normal 6800gt
Using the built in test, my system gets Minimum 24 average 43 maximum 98 1% below 25 fps 51% between 25 and 40 fps 48% above 40 fps My...
Making some progress... I have been working on the faceplate, I liked the curve idea, but dont really have a way to attach it anymore, so I...
