Okay so i have narrowed it down between two p35s and one p45, I got a n e7200, 4850, and Mushkin 2x2gb ram, i really need to narrow it down to one...
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146731 really fast reliable ram for only 2 x 2gb fro 64.99...
Ok first computer i can't remember my graphics card sadly i was to young for games so i believe it was integrated. 5200 fx [ At least im pretty...
Well first of all its blizzard and as far as i've seen they haven't really released a crappy title. Second there is no ETA because they said they...
ya right the gameplay footage was poor diablo like gaming, poor orgasm to the max and the graphics look so nice
I decided to go with the Tuniq TX-2 because there is no burn in and i believe it was superior. Ya i was goign to buy the D12SL but then i...
k i ordered and i went with the XIGMATEK HDT-S1283 plus retention bracket. this will be my first ever starting with new motherboard build.
I also just bought 3 YATE LOON 120mm Case Fan - D12SM-12 which are awesome fans and they are only $3.35 each on jab-tech since they are oem. Link...
ya they are OEM and on paper those fans look awesome
im lookign to buy the YATE LOON 120mm Case Fan - D12SM-12 fans off of them but i just want to check with you guys if you know whether its...
K so I'm putting together my final build and I have finalized my components all budget yet fast and powerful(as far as i can see) Motherboard:...
oh ok i see thanks a lot and ya im pretty sure the other psu isn't even close in efficiency considering it was built like years ago but thanks...
oh i see but overall will it be using less or more?
I think ive heard that if your power supply is ,more powerful then what you need it still only draws the power it needs right? Becasue my dad has...
thanks i now have an extra 108gb i really need that my external 320gb drive was 20gb off being full
probably just because its foxcon if something isn't reliable they just pawn it off for cheap till they get rid of their stock check out some ati...
well i would eliminate pny and go between the BFG and the xfx, the bfg is already slightly overclocked and i think regardless of brands you can...
i think its pretty awesome, its fast and the memory leak isn't bad anymore. and the address bar bookmark is pretty awesome
i have xp pro but i just made the un-allocated space into a primary drive it is still formatting though
now is there anyway i can just add it to my c drive? i mean instead of having it as two separate drives
