That was my thinking... Now, anyone got any idea on how to get my wife to say yes... lol
Alright I have a Dell M1530. Is this upgrade worth it? Id put the OS and necessary program installations on the new 64GB SSD and keep the sata...
**BUMP** Please help me out guys.
what is the performace comparison between the 3300 and 4550? Also, Whats the technical difference between 64 abd 128- bit? And, Whats the...
Well I thought the same, but most reviews do say it runs cold even w/ stock cooler. Im not gonna use that though. Anyways, Is that a good...
Well the reviews have stated that the 9950 can oc to 3.0 at 24degrees. Plus, I want a Gigabyte Board
Alrighty, I have an idea for a micro case but wanted to run the components through the wonderful bit-tech "battery" of information. My plan:...
that is what you need then
ive decided to go with a different route. Mods, Please delete the thread. And the Hardcano 12 goes to 80C stock
I need a fan controller like the hardcano 12, but goes up to 120 degrees C. Is there one, or can i mod the probes to make it that way. I want my...
i know, but 100 is all i have for the total project, i need 30 for the other part
Its 2.4 ghz, My home uses completely 2.4 phones. So iterferrence is a problem. *EDIT* this but cheaper. http://www.security-cams.com/hp200tmr.aspx
nah thats cool man, there was no other way to say it. but all im doin is tryin to go about 30 ft with 3 independent sigs audio r, audio l,...
Can be infared, as it wont be line-of-sight
I want to make 3 transmitters and recievers, obviousley on different channels to sed pure signal. Basically I want a decent composite YWR...
get the white 2 pin's and vinyl die them
Gimme a break 10am is early for me, you are correct. That link is awesome, thanks.
parallell would draw too much voltage. I have acces to two AA batteries which i believe is 3 volts.
