amazing work! just amazing... now about those hobbit feet.... lol :)
Jipa: the blue conduit that covers the power cable really doesnt jump out like that in real life, the material is that color but the flash from...
Yes I know Im bringing a dead old thread back to life..... :worried: I have just been informed by the wonderful people over at Corsair...
if it looks like a crinkled piece of paper on the surface you aren't letting it dry long enough between coats...
you did an amazing job on this project man! :thumb: :thumb: that laser etching just takes the cake though... :rock: :rock:
thanks guys :) im having some trouble taking "nighttime" shots because I dont have a tripod and they get all blurry but I should have some of...
Well I finally got this project wrapped up. Real life stuff kept getting in the way. Without further ado, I give you Project Shadow Box......
damn! thats all I can say...... Ill take 30 of em.
love the idea! I really like that you have a specific plane you are going to design for. are you planning on haveing it look a little old and...
solar i love this case, it's dimensions are almost the same as the mod I am currently working on ......
bootupbuddha: excellent, stop by and say hello at the con :D I really like the case feet that light up, so the chrome isnt likely to happen,...
^R3CoN yeah the height of those feet did seem a little disproportional to me at first, but it has grown on me. (the feet are made for real size...
Well the outside of the case is done for the most part :rock: I still need to put in all the internals and figure out a few more solutions, but...
google magnetic touch latches there are some without the touch action that just hold it closed and then the touch to open ones like on stereo...
Look at your local hobby shop in the model department or in a store that deals with models. (model cars, planes, trains and stuff) Testors...
Put that logo shown earlier in the thread on the HD cover. Im gonna clear coat it once it dries completely :D [IMG]
Another minor update: added our logo to the southbridge heatsink on the mobo using water slide decals [IMG]
I have finished painting and clearcoating and I started attatching everything together. These photos dont really show the finish well and are...
I finalized the placement for my random light stuff switches and drilled some holes for them to go. The switches are just plain black circle...
I have worked out my printable water decals. My "billboard" HD case will have a full decal on it looking like this: note: all the white will...
