easy if you know it put the bolt right through the black plate. then click on it with your right mouse button and choose "intersect with...
I would go for the normal sized hex screws. Although, I would suggest you get Inox screws match the other screws used on the outside. Have fun...
Awesome mod ( again! :D ) I was amazed by the fact that your idea was exactly what I had designed, but then a little bit bigger ( like a cube...
A wireless character LCD has been done ( he used a LPT or COM LCD and transmitted those signals in the air ( RF ) ) It worked great, but is...
just try and put 1000Volts on a piece af glass end it starts to conduct ( so it's a better conductor then air ) especially when it's hot ......
*.RAR is a WinRAR archive file. Something like *.ZIP files. You need WinRAR to extract the file. Then you'll be left with an *.SKP or *.SKB...
ever tried pen and paper ? :D It's called "oldskool", jou can just draw with the pencil on the paper and when you don't like it you can trash it...
You can try using a thyristor / Triac ( the same as a transistor but then for high voltages )
Indeed, The next time I've got a spare week I'll start drawing my home :D so everyone can virtually visit my home :p Incl the details ( like...
FYI , Google has just bought @Last Software ( makers of SketchUp ) The entire article can be read here
So , I've managed to get 6 designs ready ... not 100% in detail because of the lack of time :) I'll submit my 3 best designs :) now going to...
you can even get them real small ( not with SLI, but still with a PCI-E x16 slot :D )...
Ok, I had a nice mini-ITX design ready ( stuff is laying around, I'll I've got to do is build it ) but then I'll focus on high-end systems :)
damn, theb I'll have to select :) are you interested in mini-ITX cases ?
600 mm long , 300 mm high , 300 mm wide ( I have a series of such cases, al using 300 mm as being 1 unit :) So I could actually put them next to...
how much different designs may I show you ? I have so many ... never had the chance to built them myself ... most , or actually all of them are...
Nice one, I was always thinking, should or shouldn't I ? But never needed it, and actually forgot about it becaus eI was to busy designing...
With a remote we mean a custom made wireless remote :D Still trying to figure several things out. But we'll get to that later :D
We had it done in a local metal shop. They did lasercutting and metal construction. So I drew them a design of what we wanted, and they sent us...
wooow , amazing :jawdrop: again a darn beautiful mod by you ....
