Hello, Windows seems to be stuck in a continuous backup process. I cannot open the backup setting in control panel as this seems locked up. Any...
I have spent 3 hours looking for a 30cm braided PCI-E male to PCI-E male cable , for my thermaltake psu. The PSU came with two but Id like...
I recently had some memory problems and direct errors whilst playing BF3. I noticed that one of the GPU’s (Nvidia 460) wasn’t showing in system....
I have two identical company laptops with XP on. Because I’m out on site on a two year project they are more or less useless as you cannot do...
Nuts! My GA-M750SLI-DS4 had died. I cannot for the life of me find a replacement motherboard for the below kit. Can anyone recommend a shop or...
My PC seemed to start playing up in so much as when it crashed or I did a hard reset to post, it would freeze at post. For several months a clear...
I have extended functionality of my PC to my Plasma TV in a separate room. Essentially I have a 10m HDMI cable and two 10m USB extender cables...
I'm seeing a lot of strange activity in my router log and I'm not sure whats causing it? Sat, 2011-04-23 11:40:08 - UDP Packet -...
I have a HTPC on my network. Its connected as below Main PC > Netgear DGN2000 router > 15m wired LAN cable > HTPC I also have a Panasonic...
It’s coming to that time of year when what would first appear as a simple upgrade starts to turn into a £600 rebuild….but hey I digress. I want...
I have just replaced my aged 9800GT SLI setup with a Palit GTX 460 2048mb GS. I cannot get any driver to install, Im at a complete loss. Ive tried...
I’ve been having some problems streaming to my HTPC, video files from my main PC. What happens is that intermittently the video files locks up....
I'd like to get rid of my old freeview pvr and replace with a freesat system. As I have a decent HTPC under my TV I was wondering if anyone knows...
I have 2 x 1gb stick of Kingston DDR2 667 memory (matched pair). Both sticks work on their own but not togethor, I have tested in two different...
I have a redundant MSI K9A2 CF motherboard which I'd like to drop a Athlon II X3 435 into. Now the board makes a big deal about being AM3 ready,...
I’m confused about motherboard reviews in the CustomPC mag. At the start of reviews they give details about the board i.e. AMD 790X, DDR3, ATX,...
I'm moving the HDD & Power LED's on my CM 922. The replacement LED's have a slightly longer leg, I understand this to be the anode. When I...
I updated the BIOS on my M750-SLi to f8f (F&7) and have noticed its pretty unstable. One thing i notice at boot is the sys memory info has...
Ive just put togethor a new rig coolermaster 922. Im wanting to fit two side panel fans (2 @120mm). Behind these are 9800GT SLI gpu's. Should...
I moved all my kit from my old pc to a new case today. After firing up Win 7 x64, it BSOD's and reboots. Ive tried all the repair options but no...
