As we all know, the USB 3 internal cable is massive and blocks access to some internal parts of builds. Is there a decent right angle or sleeved...
I just this minute checked both Scan and Ebuyer and unless you want a 4GB GTX 1050ti for £155 or a dogshit GT710, you are **** out of luck. I...
Since lockdown, I am working from home 5 days a week. To try and cut down on desktop clutter and cable swapping between gaming and work, I want to...
[ATTACH]For some reason, every now and then, my Ryzen 5 3600 throttles itself to the figure shown on the screenshot. Its overclocked to 4.0GHZ...
I only have the one m.2 slot on my mobo and would like to add another m.2 nvme (m key) drive via a pcie adapter card. Does anyone have any...
I know there are some amazing extreme system builders out there but I think if I won the Lotto, I would still build by own PC. Probably some crazy...
I'm always looking at my PC setup thinking, 'what next?' to improve things. Lately, I have upgraded the RAM, graphics card and cooling (All Be...
Why no news story on here about it? Every other reputable tech site has the story but not Bit Tech. SLOOOOWWWW!
I have a Lian Li Lancool One case, so cannot install any fan controllers at the front because there are no front slots. I have set the fan options...
I've played games ever since I can remember (50 yr old) From the Spectrum days onwards, I always used Q&A for up and down and O&P for left and...
As in the title. I have just purchased a set of JBL Bluetooth headphones and would like to use them in my PC. Does it bypass the onboard sound, or...
Do I just need one of those generico £4 USB Bluetooth 4.0 dongles?
My boy is 11 which excludes him from COD, Deus Ex etc Could you give some recommendations for him other than sports and racing games he would...
I have just taken delivery of the bargaintastic Pentium G4560. I installed it as normal into my PC but I don't think I am on a late enough...
I have recently purchased Origin access and with it, Star Wars Battlefront. My controller doesn't really cut the mustard for the flying sections....
I am looking for recommendations for a low cost KM solution which would stop me faffing with unplugging the keyboard and mouse from my PC and into...
https://www.humblebundle.com/unreal-engine-bundle
Just loaded up Crysis 3 to see how my new graphics card and CPU would cope with it @ 1080p. Finally, I am able to turn every setting up to the...
I have a GX300 Antec case with a dark side panel window. I am looking for some advice on a low cost blue led solution to illuminate the insides...
I have the Mobo and RAM In my sig. The RAM runs at 2400mhz but I have read that this chipset only supports RAM speeds up to 2133. There is only...
