Hello All, Can i ask a quick question, does anyone know where you can buy them small LCD screens that fit into the CD Rom drive bay and display...
Hello All, I am looking to start planning a modification of a case, it will be my first one and also a build of a new computer. I need some...
Hey All, Can anyone give me some help with the tools :dremel: i may need to get started modding. I want to build up a good resource of tools...
Hey All, At one point their was a guy on here that was doing a mod to a Lian Li V2000 i think it was or possibly a V1000 he had sprayed skulls...
Hello all, Iam starting my first case mod and would like to design it around a comic book charecter or something simillar to that. At the...
Hey All, May i ask where is the best place to get the following and what do you recommend!!! A Drill of some kind decent enought to drill...
Hiya, Iam in the UK and am looking for a good online shop to get some dremel disks and files for cutting aluminum. Cheers Rich
Hiya i havent been here for a while so i thought i would post some of my q's here for you. I have some plans for a new project and want to use...
Iam currently developing a home network system and want to build a system that i can run all day everyday without a lot of noise. This brings...
I have Decided to start my first real mod. It is going to be based on a Coolermaster Wavemaster. It is going to have a side window which will be...
Hiya All, I have some questions regarding watercooling if anyone can help me. In the repect of adatives or anything would i need any water...
Wat graphics card should i get. It will need to be AGP as i will be running it on a Abit NF7-S The game i want to play are: - Doom3...
As iam getting older the novelty of fancy lights and colourfull cases is wearing off and the plain black cases are taking my fancy. What i want...
Iam looking for a p4 mobo iam not really a hardcore overclocker but i do play games i want something that will accept my pc3200 ram. The chip...
What is the best programme to rip my cd's to mp3 on my pc? Richman
Hi iam going to invest in a router and i have found this is this router a new revision as i seen it before and it looked diffrent. If someone...
I have recently bought a SB75G2 shuttle and i have got all my parts in it and yesterday i started it up and it worked fine but for some reason it...
Hiya I have my shuttle all ready to roll now all i need left to get is a chip what iam looking at is a Pentium 4 2.8ghz with 800fsb i dont want...
Does aol support routers if anyone knows of a good router pls let me know and i will ask around if sol supports it. If you have aol and a router...
i have found this cpu http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=6707017771&ssPageName=STRK:MEWA:IT and want to know if that...
