Wow, that sounds a lot like Ultra patenting the modular PSU. :rolleyes:
Haha, ouch. Looks very interesting though. Would like to see more...
Hehe, yeah, I've been getting more into modding rather than hardware lately. The XS L/C section is getting to be a bit intense for me sometimes....
I'm sure that Apple is already starting to feel the squeeze... our economy is "entering" a recession (I think it already is in one). The housing...
800x600 native should be fairly nice... anything higher than that still seems to be pretty pricey. 110" at 2m is pretty impressive. We had to Take...
Just fyi, the very best way to do a hand brushed finish is to use scotch-brite (or similar) abrasive pads. They can be ordered from mcmaster.com
FINISHED (well, almost anyways)! [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] Can you pick out the...
Here's where I go a bit out of bounds: [IMG] I cut a piece of thin plywood to size with the bandsaw, and made cutouts for the sata connectors...
I ditched the old power control panel since I switched to the 5.25 kaze master, so here I am making up the new one... [IMG] After engraving...
Setting up the blank for the front trim panel on the CNC [IMG] While I was waiting for the part to come off the CNC I tore the case down and...
BIG CHANGES So, first off, I need to update the system specs. -The E4600 was switched out for an E7200 -Gigabyte P35 DS3L switched for DFI...
If you look at the second to last picture in the previous post, you can see the rectangular hole I nibbled out in the top front of the case. It...
Today is radiator grille day. Here is a sheet of .080" 6061 alumiunum fixtured on the mill. [IMG] After cutting, I deburred the edges with a...
Hello everyone! I'm new to the forums as you can see, and I would like to share my first serious project with you all. This is a repost of a...
