This may sound old but also havd a good hard look at what various qualifications will pay you. For example the old MCSE/MCSA (now MCITP) don't pay...
Second the comments on the MCITP! Alot of business have and are moving away from XP - Because support ends for SP3 - Its lifed. Having said that...
I personally use Norton Internet Security, its been alright for the last two years. I like the kaspersky anti virus engine alot and I use...
I use DVDFab to rip the DVDs/Blu Rays and DIVX Plus Converter to to change to DIVX for the PS3, and I'm doing rips within DVDFab fpr iTunes...
I have the G27, its a brilliant wheel and has alot of potential to be modded. I can't really comment on the other wheel - the other is a bit of an...
Before you continue, find out what resizing is and then do it :).
Spray the case silver and gold and do a glitter mix, it will be much easier to achieve. Sainburys are currently selling glitter lamps if you want...
OMFG - PM ME SOON AS! LOL.
Hi guys, I need your thoughts. I'm planning to do a fully watercooled PC soon based around Lian Lis excellent V350 or V351. Its going...
Most budget panels yes.
Very impressive. Make sure you do lots of tidying up so only the tubing is a focal point. I think just using white light for the whole thing will...
I have the 216 core version of this card and hadn't come this problem but will look into this and let you know what happens.
That probably just leaves PCWorld and Mesh Computers then :/.
Where did you get it powder coated? I'm interested in getting a V350 done for a watercooled project but want to see more of the results first....
No offence but if your spending that much money on your rig why would you let it all down with a TN panel?
I'm just hoping you buy that 3008 so I can see some decent feedback on it :).
Yeah and its from the same ebay store I got my 27" one from so can recommend them!
Well does Sky HD look crap on your 1920X1080 HD TV? No, but it doesn't look as sharp as full HD. I suspect you would be OK. The 3008 has the...
The thing that swung it for me was the price. Under £400 it was cheaper than the 24" Dell and had less input lag. Theres a very large price gap to...
I'm sat at less than 50cm, I need to be even closer to notice anything at all. It was a worry but like I said hasn't been an issue. I agree with...
