DAM!!! i have always played GTA on a playstation and seeing as i have a PS3 and no xbox looks like that trend is going to continue!! why didnt...
I pretty much decided to get a creative vision m mp3 player (the radio swung it for me away from an IPOD) but just wondering what colour is most...
Well i heard the first lot of S12's can be a tight fit on the P180 but theres a newer model out with longer cables - i havent actually seen the...
well the new Seasonic S12's come with longer cables and defintiely fit the P180...i suppose either PSU is a quality unit...
Thank you all for the comments!! i think i'm going to go for the Seasonic S12 now although the enermax liberty 620W is running it close....
so do you reckon that the 100watt difference between the two is not really worth much - i know watt's arent the main thing!!
Okay seasonic is going into a 3-0 lead here!!!
After doing a bit of research my search for my future PSU is narrowing!! which one out of these two would your recommend for possible...
are all of the antec PSU's modular? What is the different between the truepower and smartpower models? p.s. what WATT is your Antec Newpower...
seeing good review for the Enermax Liberty 620W modular but people seem to have a few issues with other modular psu's for whatever reason
pardon my ignorance but whats a 'modular' power supply? is it when the cables arent attached to the PSU? actually what psu are you using with...
point taken about the 450W antec but i'm steering towards the P180 now that way i'm can go with a major PSU that 'should' last me a few upgrades....
i am fairly inexperienced alright built one in college a few years ago but it was a basic system...i wouldnt mind if i t took me a while to find...
yeah i was actually looking at this - seems to be getting good reviews once your not looking for water cooling - which i'm not but apparently...
I'm starting to 'compile' my new pc in the next few months with a view to completing it after Christmas with vista, Conroe et all available. I'm...
Did you try playing with bloom instead of HDR (I know it is a totally inferior effect but it should increase your performance) I cannot wait to...
i havent actually checked the FPS cause its been playing so well but i will when i get home! its pretty smooth anyway. you dont need 60 Frames Per...
nope at 1280x1024 (my lcd's max resolution) i couldnt believe how well its playing - even outdoors!!!
All this doom and gloom about having to upgrade pc's to play oblivion seems a bit out of place. at the moment i'm playing it with pretty much all...
why would a P4 3.20Ghz with HT be any sort of bottleneck for the 7800GS?
