And just when you thought it can't get any bigger for a miniITX case, Corsair comes with this...:sigh:
It's a larger piece, i only need the sides sanded <1 mm. It's this heat sink (the red areas): http://imgur.com/IIWt6hx LE: Thanks!
I need to shave ~0.5 mm-1 mm from a flat piece of aluminium (1 x 4 cm area), what dremel bit should i use and what speed? I've just got one so i'm...
Please check this other UK Kickstarter project, a game made by one person, inspired by Dizzy, call Spud's Quest:...
I can put some spacers there, so not to risk any contact. Plexi would be too think (or too fragile) and i need a way to easily attach it to the...
Thank you both for the answers. that_du^de, i just don't want to overheat and cause problems, that's all. Improving the cooling is not a goal,...
Another view: [IMG] 5 mm space, between the back of the video card and the case. Could this cause overheat? I guess i should test this the hard...
I'm thinking of a small case that will require a sheet of metal (alu or steel, not decided yet, color red in the picture) to sit ~5mm from the...
"While the lag-free connection might deteriorate over time(..)" Huh? How can this happen? You are saying that it's possible that the wireless...
Yes. Linux. :P
How come? Can you explain please? If this tool will be used for p2p public trackers, others (ie law enforcers) won't see your IP? How will you...
The power of USB3.0 is still not enough for a single 3.5" drive, as far as i know...You still need a power cable. Please correct me if i'm wrong.
You can pirate anything on pc, including DLCs. Just lower the prices (at least for digital sales) and eliminate the useless DRM. That's how you...
Does this works in coop mp without having to install the Steam Client (if i buy it from retail)? I don't use Steam and don't plan to.
No easy solution for this. And a VM of Win98, like someone suggested, doesn't work for all games. The best solution is to have an old pc with AGP...
Hmm...thx, it seems it should be fine for pci-express.
Can i use a PCI Express X16 Flexi Riser Card (like this) with a powerfull video card like nvidia 260GTX? Does the 16x pci-express riser card...
Nice article, you read my mind. :D You're saying that console and pc games can live together, as long as they are both deep and accesible. In...
I love the power and reset button idea. :clap:
Very, very nice. I'm a fan of your work. :)
