Ive been looking for an inexpensive air cooler. I'm reading that the Cooler Master Hyper 212 Plus seems to be pretty good, most sites review it...
corvette?
antec 300
If i were you, I would put it on the bottom [IMG] http://forums.overclockers.co.uk/showthread.php?t=17756187
Funny, I would have recommended a samsung monitor not unlike that one. Just don't let this used monitor ruin their reputation, the majority of...
how about Robot Frogs? [img]
yes, just cut a hole in the motherboard tray and run an extension if the cable isnt long enough.
I'd pick up an inexpensive station that will go up to at least 40 or 50w. this way you can turn down the heat for surface mounting and turn it up...
I ran my front panel cables like this [IMG]
on my gtx260, I must use unlinked to raise my core clock, with linked it seems to raise my shaders to quickly and it doesn't get happy.
you might be able to fit the card in there if you modify the shroud but I wouldn't recommend it. I was recently in a similar solution. My...
try this turn off monitor, apply accute pressure, turn on monitor
nice build, man. Looks a little like mine.
no problem with the p5q pro NB heat sink here. hovers at around 40C max temp as measured with an infrared temp gun. Plus, if you strap a small fan...
http://www.bit-tech.net/hardware/cpus/2008/11/11/intel-core-i7-cpu-value/1 :rock:
Doom + 2 HalfLife F/A-18 by Xicat the old Age of Empires MOHAA Halo 1 for PC Call of Duty 1 and 2 HalfLife 2 + ep's Counterstrike + Source...
really? I have a p5q-pro at 423mhz to get my e8400 to 3.8ghz and it runs great. My BIOS is version 1613.
Same problem with my freezer 7 pro. I ended up making a backplate out of Lexan and securing it with bolts using springs to set proper tension.
wait- you're trying to build an iron man suit out of pcb boards and components removed from said boards? good luck, dude.
I don't know, but it looks like yet another re-name. [img]
