If you have windows 7..... Do a search of this forum for "audio", you'll turn up several threads with audio problems on Win7. I had that...
Heh, believe me, I know how you feel! I've been fighting that problem for a LONG time :)
In windows taskmanager, look for "HsMgr c:\Windows\system\HsMgr.exe Envoke Manufacturer is Unknown ". I had 2 HSMgr running, one was *32, 1 was...
Windows 7, by chance? Your story sounds ALOT like mine! I started with an Asus M4A77TD, bought an Asus audio card, tried an Asus M4A78TD, all...
I personally love the logitech MX5500 set. It's bluetooth, so the range is phenomenal! I changed the 'document flip' wheel to volume, and the 'one...
+1 for cheesecake! :thumb: I'd suggest you have a look at Samsung and Vizio TV's. They give you a pretty good value. I've had my Vizio for...
I've had several Samsung DVD drives, but they can get loud. I recently stumbled onto a nice Asus drive that is much quieter than any DVD drive...
I just put this in my PC, got my drivers from there, and it does have Windows 7 32 as well as 64.
Thanks for the fast answer, Goodbytes! I'll give that a shot when I go back over there next weekend.
My mom's PC shows picture thumbnails like this: [IMG] Does anyone know what the blue arrow thing is, and how to make it go away? She has...
As in "on the static bag that the motherboard was shipped in"? Don't use the bag, the cardboard box is safer. My money's on a failed motherboard.
I've had that problem in the past; when you boot up, it says something-or-another (bootloader, I think?) file not found, correct? Disconnect the...
I re-registered my OEM online, after building a new PC & swapping the drives into their new home without reinstalling Win7. :thumb:
Thanks Krikkit! I installed both. When I tried MPC-HC, I get full audio, but no video. :grr: When I use VLC, I get full audio and video. :D...
Thanks Badders. When I set Media Center to two speakers, I got all of the audio tracks, but now the image is scrambled. Keep the ideas coming...
Thanks for the prompt response Omnituens! I'm pretty sure that used to be the case, but they have eliminated the need for that 4 pin wire. I...
New to the site, but you folks seem to have some very insightful information. I recently built a new system : {Asus M4A77TD} {AMD Phenom II...
