Most likely a oc stability issue but there could be other things: Is it running fine of default clocks (just reset the CPU)? What's the...
Micro ATX Intel H55 Chipset Motherboard with 1 PCI Express x16. Compatible with 5670? Yup. Novatech PowerStation Gaming 400W Silent ATX2...
Hmm, at 57% fan speed, it would be fairly loud. As suggested, MSI Afterburner and set fan profiles to your liking. 60c is cool for a graphics...
Apologies for asking but you'd never know: You have a 64-bit OS, right? Now, it sounds to me that it could be a failed ram stick or failed...
Budget as in a desktop no gaming build? Yes. But definitely go for solid name brands when you're looking to build even a low end enthusiast PC....
1920x1200? And the 6870 is struggling with it? What's your CPU? I thought a OC'ed 6870 could do Crysis maximum settings at that res fairly...
dBA measure Depends on what 460 you get. And here: 460 Cyclone
Agreed. No point getting a 560 if you just need a card to tied you over until a new build. If you're planning on the November wait, then...
For your res, and what you want to play in the near future, you won't really need more than a 460 or 6850. 460 vs 6850 They're also the...
Fixed. You weren't supporting piracy of course, were you? ;)
Still using my Logitech MX 518 and still love it. They have great customer support too so when I do need another mouse, I'm going to look at the...
I really enjoy my 360. Plenty of great games without having to worry about driver issues and incompatible versions. And it's great just having...
The Green Hornet - 5/10 Hollywood switch off movie.
A passive PSU? As for a passive GPU would be something like this: ATI 6850
Been buying F3 HDs recently. I really hope I haven't got a bad batch but I reckon their failure rates are pretty damn low as hard drives go.
:eyebrow: Ah well, let's see what it will be like.
Same except with 3gb RAM. The RAM makes so much difference. Half tempted to overclock the CPU but I don't trust the fan and dell :D
Looks sweet but will cost way too much for it's features :sigh:
43 Piece Kit And 23 Piece Kit I have the 23 piece kit. Definitely recommend the 43 piece and buying a head torch.
Anybody know about PowerColor for ATI cards? Apparently they don't do RMA for Europe?
