Thanks you for nomination great site and great mods
Thanks all
Thanks
Thanks I will be doing a video in a few days will post a link
[IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
Final pics [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG][IMG] [IMG][IMG] [IMG] [IMG] [IMG] [IMG]
Leak test done [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
Toughpower PF1 ARGB 1200w power supply fitted cable management done , now to fit some fan controllers and tomorrow bend some PETG stay tubed....
Fans fitted, radiator mounts cut and painted. Quad rads fitted and usb hubs. Tomorrow make a holder for the psu and do some cable management. It's...
The Thermaltake and stock back plate is to thick for the Asrock Fatal1ty X399 Professional Gaming Motherboard so decided to make a custom one....
Well Project Firewater is starting to take shape, need to make a custom gpu back plate and a window for the Seagate 4tb Iron Wolf hard drive. In...
More prep work done this weekend primed ready to paint. [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
Case painted and rebuilt the surround has a few more adjustments and then ready to prime. [IMG] [IMG] [IMG] [IMG]
Managed to get more work done filling in screw holes and get the rest of the parts and materials i needed before lock down. [IMG] [IMG] [IMG]...
Extraction fans on the top of the mantle piece. [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
Now for the hard part cut the holes for 120mm fans and quad rads which will be mounted in the pillars. [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
Now for the mantle ie top [IMG] [IMG] [IMG] [IMG] [IMG]
thanks
Now for the fire back plate which will mount the pc [IMG] [IMG] [IMG] [IMG] [IMG] [IMG]
