Thanks @true_gamer. I'll stick with using an extender for now. I'll probably purchase a newer more powerful model in due course. If the difference...
Thanks @true_gamer. The VR900 is more similar to the VR2800 than the VR2100. The VR2100 uses a MediaTek chipset whilst the VR900 and VR2800 use...
I've just ordered a replacement VR2800 router as my old one soon stopped powering up after using the light switch set off the trip switch....
The issue's resolved for me now. I posted on the TP-Link community forums and one of their staff suggested I change the channel, channel width and...
Unfortunately the issue remains. I tried switching off both Wi-Fi connections, assigning channel 6 to the 2GHz then re-enabled both. But it...
Thanks very much guys. I did wonder before posting whether it was channel selection but discounted this as when testing it would say it cannot...
Both the 2GHz and 5GHz channels are set to automatic but this hasn't been an issue before. I'll try this and see what happens. Cheers!
I have a TP-Link Archer VR2800 router which has been working perfectly for 3 years up until now. For the past few days whenever a device attempts...
Thanks guys for your advice. I have passed it on to the gentleman so waiting to hear back. This is the camera model.
I thought I'd be a 'good Samaritan' and post on behalf of someone else. The gentleman has a Virgin Super Hub 2 router connected to a Hikvision...
Unless I'm mistaken. With Powerline you have to ensure all the adapters are on the same electrical circuit? Not sure whether this only applies to...
Funnily enough an update came out yesterday which I've installed so we'll see!
My current router which is the best I've ever used is the TP Link AC2800/Archer VR2800. Altogether there's 11 devices that have connected to it (3...
Just curious to know why a reboot/power cycle is the only fix whenever a device can't get an IP nor internet connectivity on a router over Wi-Fi?...
You guys can try G2A as well. But the UPlay points is a great shout as it's 20% (£10) off with 100 points and I'm fortunate to have 200!
@Big_malc feel free to PM me mate when you're free for a game. @Otis1337 I get what you mean with all the mods out there. Although with most of...
Rising this thread up through the ground again. I'm running a KP Liberation mission on my server. It's basically Capture the Island except it's...
Hi guys I'm looking to replace the BT Home Hub 5 we're currently using at home. We purchased it in Jan '16 and it worked fined until around Jan...
Hi, I have an old PC with a C drive (primary) I'd like to clone to a new PC's blank D drive (secondary). New PC already has a different copy and...
Thanks very much guys, you've definitely helped me make my mind up! Yeah my mistake I meant to link ROG SWIFT PG279Q. After reading the replies...
