Thanks for your constructive help instead of the crass comments below. I need philosophers right now like a hole in a head!
I do as it's still on the plastic sleeve of the Windows 7 x64 Pro disk, which in itself was a Student Discounted special Upgrade from Windows XP...
All of a sudden, just out of the blue, after I had re-installed some software this afternoon, I now all of a sudden get a faint in grey...
Guess what, a certain big IT supplier in the Lancashire region just does not like criticism it appears, on what it sells. I had bought a Fractal...
I like yours Jeff. Just what I am looking for but am not 100% if it will power a USB device VCC1 D-1 D+1 GND in this configuration @Anfield,...
I am looking for a cable that has one female 9-pin header connector at one end and a splitter into 2x male 9-pin connectors at the other end. I...
Really, really appreciate such a very helpful piece of advice. It's taken a load of worry off my mind. Now, thanks to you, I can relax.
Thanks for that. Next question, what or how are they re-filled then when the coolant runs low due to evaporation, etc through the radiator to CPU...
A novice's question. Just bought an NZXT Kraken X52 AIO. It is my very first venture into AIO cooling. How is an AIO filled with the coolant?...
Thanks Jeff, and Zoon for that. Noted.
I did exactly the same Re-install Windows 7 x64 Pro, or the Windows 10 x64 Pro? I loathe calling MS. Kept on hold, costs a fortune. Will bear...
Two-three years ago, when MS was offering universal Free Upgrades for OS, took the opportunity to move from my existing Windows 7 64-bit Pro to...
Thank you very much for that. Taking a look and read right now.
Can anyone kindly shed light, then on which one of these panel types are good displays ? TN, VA, or IPS? Currently have a Dell 24-in IPS and it...
Just read user's Reviews on one of those Samsung displays----not recommended due to poor input power cable design. Typical Samsung hype in their...
As I only play flightsims, I am looking for a recommendation while the Black Friday sales are on, to pick up a 32-inch display, e.g. Samsung 3840...
Thanks for that reply. Appreciate it. Only game I play is flight simming an that is a CPU-intensive game.Do a lot of photo-editing, and music...
If I can kindly jump in here and ask a question, please furnish a suggestion/answer if you have one. Just had my Z390 Asus ROG Maximus XI Hero...
I did say I had to gulp twice when I used that configurator and came up with more or less same sums as you have just listed. Food for thought. As...
Thanks for that link. Wow, did not know such a tool existed to configurate. A doddle to use. Only the £1/2 grand is a gulp-maker, in comparison to...
