About to clear 1.5B. Just entering the long slog of no other active folders until I hit 3B! I'm coming for you Dave... Just give me 9 months.
https://www.theguardian.com/technology/2020/nov/30/deepmind-ai-cracks-50-year-old-problem-of-biology-research Interesting
I'll PM my address for when you are finished
1,000,232,159 :) Was my goal to hit 1B before christmas so well chuffed. Not sure how much longer I'll keep going, need to see. Was hoping to...
a: yes - but may change with 6000 series b: can run various together as long as you have enough cpu cores to keep them supplied
https://folding.lar.systems/folding_data/gpu_ppd_overall 3090 5.5m PPD Average with a peak of 7m 3080 4.5m PPD Average with a peak of 6m
My sentiments exactly, thats life. Just have to work with the hand you are dealt. We went through this two years ago, 5 surgeries in total and...
Looks like my sons tumour might have started growing again, got some follow up to do so we can make sure, might have to start chemo which we were...
I did wonder what had happened, noticed my output jump up quite significantly.
Hourly Production Time Points WUs 09.21, 6am 0 0 09.21, 3am 0 0 09.21, 12am 0 0 09.20, 9pm 0 0 09.20, 6pm 0 0 09.20, 3pm 384,916 1 09.20, 12pm...
Just had to take myself and the 3 yr old for a test, no symptoms but we are going into hospital as he needs a scan for something else. Not sure...
Friend of mine had an industrtial carpet shredder, ran off a 150kVA generator. The motor on this thing was incredible, 75kW, about the size of a...
That's about 8 days away at your current rate. Still get some resale in your current cards too, although not as much as two weeks ago. 2080ti seem...
Who's for an upgrade :) 3080 should be a fantastic folder, price not to bad either.
Don't worry, if they catch it they will just shove them into care homes.
Not entirely, it will reduce transmission through coughing/breathing but you are still buggered when having contact with surfaces, hence...
Brilliant fix, love it.
Use nvme on 1 windows machine, no issues with rebooting here. Try shifting the installation onto the boot drive.
Using you as an example, 21m PPD, 2080Ti is average 3.2m PPD you need 6/7 of them. £1300 each plus two systems to split them between you are £10k...
25th of November and you will be 2nd... Middle of 2023 before you catch the Doc lol. That's me hit two milestones, 500 million, plus, on a...
