I got into an argument with someone on the SoundOnSound forum once when I was asking for advice about my FireWire audio interface not working...
Just arrived and installed, running smoothly.
Also just seen the MS FAQ which says Only USB3 controllers from Intel and Renesas are supported but having read a little bit I'm reasonably...
Thanks, I've ordered one from Scan now. One of these which the description says uses "the best NEC chipset", so fingers crossed it'll be ok. It...
I suppose I could also get a USB 3 PCI card.
I have a Kinect for Windows sensor I'm trying to use with the system described in my sig; notably ga-ud3h-b3 mb. The Kinect v2 Configuration...
Working fine with the new inverter FWIW. Thanks again.
Thanks guys!
I thought that the socket on my Nexus 4 was dodgy... maybe it is slightly, but it turns out that it's heavily dependent on the micro-USB lead I...
Handbrake is a handy tool for that part FWIW (I realise this is probably about the most trivial aspect of what you're trying to find out).
I have a Dell Vostro 1500 which has been going strong for quite a few years now. Recently the screen has become dim (almost completely dark -...
Probably not relevant given you say the GPU is either a 2400xt or 2600 pro, but there's a replacement program for dodgy 6970s in iMacs:...
I can't seem to get this machine to boot from USB since updating to UEFI BIOS / installing Windows 8. I can't see any options related to this in...
So I've disconnected the front panel card reader thing. Thought it seemed better, but I did experience a crash this morning. Somewhat different...
Worth a thought... I have a cheapo front panel card reader thing that I *think* I eliminated (must be two years since I was properly testing, so...
I have a machine as listed in my sig. I posted a bit here around the time I put it together. The SSD was added some time later. It's always had...
I think it's safe to say optical disks today are pretty equivalent to floppy disks about the time Apple stopped bothering to include them in their...
Hmmm.... that looks like a sure-fire winner ;) In all seriousness though, that's very wrong and I'm afraid it's going to give me nightmares....
The question about AA is one I feel I really ought to be able to answer quite easily, but feeling too stupid at this precise moment. :sigh: I...
The interesting thing of course being, that whatever the intrinsic technical merits of the technology, Apple do have a big influence on trends at...
