Hi all, I need a bit of advice. I bought some bits from China in the summer that required some import duty paying. I paid all the invoices I...
It seems a bit strange to me how motorbikes are so loud when I’m sure there’s strict regulation for cars. I love in central London and while...
Thanks both. Like I said in my first post, I have decided to trade efficiency for size. To get the output I desire I'll just apply some EQ. Jean...
Thanks for the comments. I have ordered the driver but I won't get it for another ~2 weeks due to it being ordered from the manufacturer....
I hope this is allowed here. I understand it's not a computer case but the rules don't mention that... Anyway. I built a pair of active two way...
Can you post a photo? I can most likely do it. See the link for something I typically design and hand make....
Very good! I love ToT
This is really not going to work. Just look at the body diodes of the FETs. USB can’t be considered as just an ordinary signal, it has...
As above really. I remember the GTX 295, HD 4870 x2 and such. Why not anymore? One GPU can crank out enough heat on its own?
I am just a layman when it comes to politics, FYI. I've always had a problem with the royal family, I love them, I feel it's something special...
Hi all, I'm currently making myself some bits where I have made my own keyboard interface (not QWERTY) with Cherry MX switches as they (and the...
I'm sure this has been done to death already and from 1.6 to source. I recently played GO for the first time from the recommendation of a...
Hi all, I'm going to be making a server rack out of plywood by stacking CNC cut pieces together to form the profile. I like the aesthetic of this...
Agreed. Stupidly I went for the big iPhone a couple of years ago. Now I’m wishing for a top spec iPhone 5. I know I’ll never get it however.
Sorry, it was the phones. I should have explained better. The second part about the laptops is an addition to support my negative feelings towards...
This kind of isn’t a rant, more of a start of a discussion. Do we really need these things for our phones? I mean I’m fine with them and I’m...
These are just standard 2.54mm pitch headers so it'd be very simple. You'll be fine having the power run across the PCB, as long as the traces...
I would download Eagle and start playing with it, follow some tutorials. Once you have an understanding of how it works you need to look for the...
Thank you all for your advice. I think I'll just take it a little easier on the work then, the new year should be a little tamer. I'll let things...
I'm sure this is a problem for many people just not sure what to do about it, if I should at all. So I've chosen to be single for a couple of...
