Just caught up with this from the homepage, congrats on the nomination and it's a wonderful build!
Love the alternative radiator that you had used! I looked into one of those 2x80mm but wasn't sure about the cooling ability due to the size. This...
Well here's an update from the past few days. I got the block mounted - I thought the wiring would be stupidly clean, but then I remembered I...
Thanks Kim! I'm just putting off filling the loop at this point it feels like. I'll have to just get it done. I am planning on doing soft tubing....
Hello all, So I've got a relatively simple project, limited in scope as a mod. It's a Chenbro RM-F41300. It's a 4U case with two 80mm fans above...
Looks awesome cheap!
The case and radiator shrouds are awesome, extremely well-executed. But, that wiring is so far beyond anything I've ever imagined, dang yo that's...
I'm so tempted by this. I was playing WoW when BWL was new, and I was 16 or so. Well I'm much older now and have responsibilities other than...
That is a clean as hell build. It's so dang crisp. I love a retro mod, and I love a sleeper. This is both on steroids. Excellent work!
This is some awesome paint! Looks awesome!
Over the past ten years I've had 4 in my primary desktop. the corsair replacement was a misdiagnosed PSU issue. I've had about 4 builds across 2...
Dang this is a clean build, love it!
I do enjoy the color purple! Looks awesome! Also threaded rod is one of my favorite things to use, love seeing it used! Keep up the great work!
Thank you Landux, very kind of you to say that.
Thank you very much Kim, you're very kind to say that. I definitely tried to up the photography level from slightly dim basement workshop and...
Thank you, it's what I was going for at the end of the day. Maybe, you're just right. I jest, but appreciate it! Also regarding Eric, f$*% that...
Bummer about the board, but I understand! I can appreciate you ripping apart a defunct one too. I'm sure it'll turn out great, your other stuff...
Hello everyone, Thank you for your votes for April's Case Modding Update of the Month! I'm truly humbled. Got some final pictures shot of the...
This is awesome! Edit:This is such a cool concept, done to an extreme! off-the-shelf in a custom package without the totally custom parts! I'm...
Love an ITX build! Really digging the graphics on the side panel, has a visual effect of a comic book style of graphics. Looking forward to see...
